Thread started 07 May 2007 (Monday) 14:46
RAW and colorspace
narlus
May 07, 2007 14:46 |  #1
probably a dumb question, but are both Adobe RGB and sRGB available to RAW images, and chosen via the dropdown menu in Adobe Camera RAW? about all i know is that the gamut is wider for Adobe RGB, but you need to convert to sRGB for web use.
i should probably learn more.  :o
anyway, i did see in the 30D's menu a place to select one or the other, but if i shoot RAW does this matter? is it only for jpgs where it gets selected at this stage?
www.tinnitus-photography.com (external link)
Facebook link (external link)
gear list
In2Photos
May 07, 2007 15:11 |  #2
Both options are available in ACR as well as ProPhotoRGB. When shooting RAW it does not matter which color space you choose until conversion. Note that images in sRGB will use the image numbering system IMG_xxxx.cr2, while Adobe RGB will use _MG_xxxx.cr2.
Current Gear and Feedback
René ­ Damkot
May 07, 2007 16:07 |  #3
Also, the 'in camera' setting affects how the image is displayed on the camera LCD. (As do the parameters in camera).
You might wanna check a few of the links I put in the post linked from my sig ;)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
narlus
May 07, 2007 17:33 |  #4
In2Photos wrote in post #3167043 (external link)
i was wondering about that. thanks!
rene, i will def check out that sticky thread.
gear list
1,086 views & 0 likes for this thread, 3 members have posted to it.
RAW and colorspace
2814 guests, 158 members online
