Thread started 04 May 2004 (Tuesday) 21:31
Flash Exposure with EOS 1D Mark II
Mike ­ H
Joined Jan 2004
May 04, 2004 21:31 |  #1
Has anyone with a Mark II tested out the new flash metering system (E-TTL II)? I would be interested in any test results, especially if bounce flash were tested. Thanks.
Mike
nosquare2003
Joined Dec 2003
May 04, 2004 21:47 |  #2
I'm interested too.
But can ETTL II be used in bounced flash?
Mike ­ H
Joined Jan 2004
May 04, 2004 21:50 |  #3
It would be of far less value if it couldn't be.
Mike
nosquare2003
Joined Dec 2003
May 04, 2004 22:13 |  #4
I read from here:
http://photonotes.org/​articles/eos-flash/#ettlii (external link)
Mike ­ H
Joined Jan 2004
May 05, 2004 05:41 |  #5
From the site that you cite ...
<<Distance data is not always used by E-TTL II. There are three very significant cases in which distance data is not used, aside from the obvious case when it isn’t available because the lens doesn’t provide it. These three conditions are bounce flash, macro flash and wireless E-TTL flash.
When you’re using bounce flash (ie: when the flash unit’s head is in basically any position other than full-on straight) then there is no way for the camera to know the distance the light took to reach the subject from the flash.>>
I disagree with this author. Distance data would be quite valuable in this situation. The metering system knows how bright the area at the focus point was before exposure and after the pre-flash was fired. It also knows the intensity of the pre-flash that it fires. And the system knows that you are in bounce mode, i.e., it can tell that you have the flash head pointed up. Using all of that information, it can calculate how the pre-flash was affected by the combination of distance and reflectivity of what it bounced off of. From there, the camera's computer can determine how much flash to fire to cause the object at the focus point to be rendered as a mid-tone given the shutter speed, aperture, and ISO setting in use.
One problem still remaining is that you may not be focused on a mid-tone. Still, if the system really works that way, it's some progress .... I hope. Of course, I'm speculating. We do that a lot here. :)
Thanks for the response.
Mike H
1,281 views & 0 likes for this thread, 2 members have posted to it.
2130 guests, 130 members online
