Thread started 08 May 2007 (Tuesday) 22:51
How to batch watermark in Photoshop 7.0 with an EPS?
cdifoto
Don't get pissy with me
May 08, 2007 22:51 |  #1
I have an EPS file from a web designer with my logo. I want to automate using this as a watermark on my images, with it being in the same place regardless of image size. How can I do this? I've tried an action but I'm failing to set it up properly - assuming it can even be done with an action. If it needs to be a script & anyone knows how to do it that way I'd appreciate the help. But I really don't care if it's a script or an action, as long as I can do it.
Thanks in advance.
cdifoto
May 09, 2007 05:43 |  #2
OK I sorta got it figured out. But I'm wondering if anyone knows how to make the location absolute rather than relative. Or maybe I want it relative instead of absolute. I'm not sure. :oops:
I just want it to show up in the same location each and every time, instead of being dependent upon the image dimensions.
René ­ Damkot
May 09, 2007 12:37 |  #3
Have a look at russel browns' site (external link). There is an action 'Digital Watermark Branding'. Look at the QT movie. Might give you some ideas ;)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
cdifoto
May 09, 2007 14:29 |  #4
Hmm thanks for the link Rene. I'm off to a good start from that, but since I'm using an .eps graphic file instead of a path some of the steps don't apply. I'm still having problems getting the watermarks to be the same size on both images. Alignment is good but there's a discrepancy in the actual size of the watermark. Oye.
2,876 views & 0 likes for this thread, 2 members have posted to it.
2818 guests, 157 members online
