Thread started 09 May 2007 (Wednesday) 03:18
Vignette - help?
sando
May 09, 2007 03:18 |  #1
Hi,
been playing around with Vignette's at the moment and cant quite get my head around something... it's one of those simple things that bug you loads!
Okay, say you have a portrait.
In CS2, you only have 1 layer, the 'background' layer.
What I normally do is:
Lasso around the subject.
Adjust feathering to 250px.
Invert the selection.
Copy and paste the selection to a new layer.
Adjust Brightness and Contrast, Saturation and Gaussian Blur.
Done.
The only problem is, I want to use adj. layers instead, so that I can adjust the vignette afterwards if I decide it's too dark, too light etc...
Anyone got any ideas?
One I thought of, is saving the selection and the adding a layer-mask to each of the adj. layers - which should then use the selection as a layer mask.
- Matt
tim
Light Bringer
May 09, 2007 06:11 |  #2
Layer opacity to control the strength of the vignette. Link to my vignette technique in my sig.
René ­ Damkot
May 09, 2007 12:35 |  #3
Do the same 'lassoing', then make a curves or levels *adjustment layer*
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
sando
May 10, 2007 02:39 |  #4
Rene, I have tried that, but... when adding an adj. layer it controls everything below it... hence; it would adjust everything, and not just the new layer with the vignette on it.
- Matt
tim
Light Bringer
May 10, 2007 02:39 |  #5
Did you read my post at all? I gave you the solution.
Sam
May 10, 2007 02:41 |  #6
tim wrote in post #3181933 (external link)
I'm sorry did you say something? :p
René ­ Damkot
May 10, 2007 03:34 |  #7
While Tims method is one way, you can group an adjustment layer to a layer, by alt-clicking between the two...
tim
Light Bringer
May 10, 2007 03:50 |  #8
René Damkot wrote in post #3182055 (external link)
Hey that's kinda helpful.
sando
May 10, 2007 04:17 |  #9
Never knew you could do that.
Tim, I did read your reply, but the issue is with your method is that when applying more than one edit (such as brightness, saturation and blur) it doesnt allow you to adjust each one seperately, if you wanted to change it later on.
I sort of found the solution now....
I lasso as normal.
Feather as normal (250px)
Then instead of inverting, I use the selectection I made, copy and paste into a new layer
Then use the adj. layers below the new layer.
- Matt
Yella ­ Fella
May 11, 2007 05:19 |  #10
i have to try that, i keep getting confused about this vignette thing
i tried to follow tim's as its pretty cool vignette he has, but i can never get it to work somehow! grrr!!
Ed - www.edwardlui.co.uk (external link) | modelmayhem (external link) | facebook (external link)
Canon EOS 5D x2 | Canon EF 35mm f1.4 L USM | Canon EF 50mm f1.2 L USM | Canon EF 85mm f1.2 mkII L USM | Canon EF 24-70mm f2.8 L USM | Canon EF 70-200mm f2.8 IS L USM |Canon 580EX mkII x2http://www.edwardlui.c​om (external link)
1,239 views & 0 likes for this thread, 5 members have posted to it.
Vignette - help?
2734 guests, 156 members online
