hi
how do i do this
am trying to resize a jpeg to send but the person needs it 300 dpi and its currently 72. i have dpp installed on my laptop, no other means to process.... any help gratefully received
cheers
michael x
freeekunique Member 39 posts Joined Aug 2006 More info | May 09, 2007 18:19 | #1 hi
May 09, 2007 18:24 | #2 do you have the raw or original file? Louisville Kentucky Wedding Photographer
goforphoto Goldmember 2,067 posts Joined Nov 2006 Location: Virginia More info | May 09, 2007 18:24 | #3 If you go from 72 dpi to 300 dpi you will end up with a really crappy print. Best to send original file at 300 dpi Just another shutterbug.
hi
goforphoto Goldmember 2,067 posts Joined Nov 2006 Location: Virginia More info | May 09, 2007 19:02 | #5 If it is the full size jpg just resize by changing the pixel size, 2400x3000 at 300dpi would be an 8x10 while 2400x3600 at 300 dpi would be an 8x12. Just another shutterbug.
Galaxy99 Goldmember 1,142 posts Joined Feb 2007 Location: So. Cal More info | May 09, 2007 19:16 | #6 crop to 4x6 (or any fixed size), then take a look of the PPI in image size, you will see the wonder.
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | May 09, 2007 21:18 | #7 freeekunique wrote in post #3180100 hi how do i do this am trying to resize a jpeg to send but the person needs it 300 dpi and its currently 72. i have dpp installed on my laptop, no other means to process.... any help gratefully received cheers michael x What's the size of the original in pixels? And how big a print does your friend want to make? The actual dpi is irrelevant at this point because that can be changed on the fly without necessarily changing the actual physical attribute (pixel resolution) of the image file. ...Leo
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | May 09, 2007 21:22 | #8 goforphoto wrote in post #3180118 If you go from 72 dpi to 300 dpi you will end up with a really crappy print. Best to send original file at 300 dpi How do you figure that? Changing your dpi does not mean that your image size has to change. AAMOF, if you look at the image resolution of your files coming out of the camera in JPEG format, you may notice that it is at 72 dpi. Does that mean that you won't be able to get good prints with the files coming out of the camera, then? ...Leo
goforphoto Goldmember 2,067 posts Joined Nov 2006 Location: Virginia More info | May 09, 2007 21:38 | #9 Look at the inch size of jpg images right out of the camera. they are 30 something by 40 something inches. when you print the image to an 8x10 inch size the quality of the image automatically increases. Most print companies require 300 dpi cropped to size not a huge jpg that they are going to have to resize. Just another shutterbug.
RodBarker Senior Member 464 posts Joined Apr 2005 Location: Hervey Bay Australia More info | May 10, 2007 00:00 | #10 In PS open your image ,, then go image> image size> then select under document size inches and type in your reqired print size and dpi , make sure constrain proportions is checked so you dont distort the aspect ,,, then if your upsizing select Bicubic smoother , if downsizing select bicubic sharper and select OK .
BillBoehme Enjoy being spanked More info | About the only time that you would need to be concerned about the PPI is when you are putting the image in a PDF document that will be viewed on a computer and you want the size to be scalable without having the images getting "blocky" when the image is magnified. Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
BillBoehme Enjoy being spanked More info | May 10, 2007 02:54 | #12 RodBarker wrote in post #3181483 In PS open your image ,, then go image> image size> then select under document size inches and type in your reqired print size and dpi , make sure constrain proportions is checked so you dont distort the aspect ,,, then if your upsizing select Bicubic smoother , if downsizing select bicubic sharper and select OK . Rod Yikes, somehow I missed seeing your post. Sorry about repeating the same thing. The only thing that my post adds is the info about the potential for free beer. Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | May 10, 2007 05:56 | #13 Both you guys need to read the OP again. He has only DPP. Elie / אלי
zacker Cream of the Crop 6,006 posts Likes: 7 Joined Jan 2005 Location: Oxford, CT. More info | May 10, 2007 06:05 | #14 i dont find going from 72DPI to 300 degrades the photos print at all? am i missing something here? I always save @300dpi mostly because my Epson printer loves 300dpi or higher for some reson and i was told the ONLY reason to use 300DPI would be for printing. http://www.theanimalhaven.com
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | May 10, 2007 06:38 | #15 zacker wrote in post #3182332 i dont find going from 72DPI to 300 degrades the photos print at all? am i missing something here? I always save @300dpi mostly because my Epson printer loves 300dpi or higher for some reson and i was told the ONLY reason to use 300DPI would be for printing. have I been lied too on this site?? Hmmmmm?? lol Changing the nominal dpi listed in the Exif will not degrade the image and it will not enhance the image. It will not do a freaking thing to the image. It's only a number they (Canon) put in the Exif because the standard says they have to write something there. It has the same effect as changing the date. What matters is the functional ppi which is determined by two things only, image pixel dimensions and print dimensions. Elie / אלי
| Latest registered member was a spammer, and banned as such! 2571 guests, 152 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
