Thread started 10 May 2007 (Thursday) 07:08
Who uses lens hoods with flash "at night"?
cookie99
May 10, 2007 07:08 |  #1
:) I am concerned as to whether I should use my lens hoods on my wide angle lenses indoors at night.
Any advice appreciated.:o
Chris Cooke "Me transmitte sursum, Caledoni"
cdifoto
Don't get pissy with me
May 10, 2007 07:11 |  #2
I don't take my hoods off. Ever. I only reverse them for in the bag. Not sure why you think the hood is a concern. You should be either bouncing your flash or pulling out the wide angle panel on your 580EX.
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
May 10, 2007 07:13 |  #3
I keep mine all the time, it not only stops flare, but also protects the front of the lens.
Give how big the lens element is on the 17-70 I consider that quite important (yes, there is also a UV filter there, but I tend to take it off when using flash, as it often catches bad reflections).
Unless your using the on board flash, any hot shoe mounted flash is going to reach over the hood in the vast majority of shooting situations. Especially if you are bouncing it ;)
The only time a hood might get in the way is if your shooting macros, in which case the hot shoe is not always the best place for the flash to be.
Have you Calibrated your Monkey lately?
Now more than ever we need to be a community, working together and for each other, as photographers, as lovers of photography and as members of POTN.
Converge
May 10, 2007 07:16 |  #4
like others, i always use mine. I dont use a UV filter so the hood is my only protection for the front glass. I reverse it to put it back in the bag
http://www.ericforberg​er.com (external link)
MrWills
May 10, 2007 07:27 as a reply to  @ Converge's post |  #5
I'm the same they are always on.
Shawn
www.shawnwillsphotogra​phy.com (external link)
scottbergerphoto
Joined Jun 2003
May 10, 2007 07:49 as a reply to  @ MrWills's post |  #6
Good protection for the lense. I always use the hood.
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography (external link)
cookie99
May 10, 2007 07:59 as a reply to  @ scottbergerphoto's post |  #7
Thank you all, the advice is much appreciated and will be followed.:eek:
AlexMa
May 10, 2007 08:35 as a reply to  @ cookie99's post |  #8
always on...............
I get strange looks and have been told "that's used whent he sun is out".
It's still the best protection out there for the front element.
2,017 views & 0 likes for this thread, 7 members have posted to it.
919 guests, 109 members online
