Thread started 06 May 2004 (Thursday) 13:33
Slide copier
ahmadof
Joined Jun 2003
May 06, 2004 13:33 |  #1
has anyone had any experience with somethiong like this
http://cgi.ebay.com …0066&item=38130​94389&rd=1 (external link)[URL]
does this work as well as a scanner. Can i use it to archive old slides without loss of quality? What is the best/ most cost effective way to archive a ton of slides?
nikee
Joined Jun 2003
May 06, 2004 13:45 |  #2
ahmadof wrote:
What is the best/ most cost effective way to archive a tone of slides?
project them on a screen, shoot them with a digital camera on a tripod. you can do about 100 pieces per hour that way. delivers high quality, high speed and low cost digital copies.
regards
nicola
Cadwell
Joined Jan 2004
May 06, 2004 14:02 |  #3
Advances in high-index / low-dispersion optical glasses, new barrel materials, and exotic anti-reflection coatings, along with the latest in computer-aided-design / computer-aided-manufacturing), are combined to produce lenses of unprecedented quality. Diamond-cut from crystal-clear, water-white optical glass, Opteka lenses are ground and polished to a precise precision.
All that for $59.99? Call me cynical if you like but I can't see it somehow. :lol:
I've never done slide to PC transfers but a colleague uses a slide film scanner which produces very large high definition images. He's very pleased with the results but I suspect it's not a cheap one knowing him. I believe they start at around $150 but you probably "get what you pay for" in terms of quality.
Glenn
My Pictures: Motorsport (external link)/Canoe Polo (external link)/Other Stuff (external link)
PacAce
Joined Feb 2003
May 06, 2004 14:29 |  #4
If you're going to be using the 10D or DRebel or other non fullframe camera then you won't be able to get the whole slide in with that. You might be better off getting a lightbox and a macro lens and shooting your slides off of the lightbox. That's what I did with my old slides and the quality really surprised me. It was really very good!
BTW, if you're going to do it with the lightbox and a macro lens, I would also recommend the angle-c viewfinder.
...Leo
boBquincy
Joined Nov 2001
May 06, 2004 17:30 |  #5
B&H also has a few different slide copiers, mainly based on the same idea. The problem is the 1.6 multiplier will copy only the central 60% of the slide.
One of the B&H models has a zoom feature but it appears to only magnify, the opposite of what I need for my 10D.
I'm thinking of getting one of the lower priced ones and trying to change the distance from the camera to the lens and from the lens to the slide to get the proper magnification. An OttLite or even diffused sunlight should make a good light source (after white balance correction).
boB
2,688 views & 0 likes for this thread, 5 members have posted to it.
Slide copier
2121 guests, 130 members online
