Thread started 11 May 2007 (Friday) 15:11
Can someone help me cut
tania622
May 11, 2007 15:11 |  #1
these two little girls out of the picture and put them on the bottom left corner of a 5x7 leaving enough space to write. I want to make some invitations for their mom's baby shower that look sort of like the 3rd picture I'm posting.
If it's too much work, can someone tell me how to cut them out? I know you use the laso tool but when i try it, it looks like i cut them out with scissors and they look chopped... :oops: TIA
IMAGE: http://i101.photobucket.com/albums/m56/tania622/IMG_0502.jpg?t=1178913907
IMAGE: http://i101.photobucket.com/albums/m56/tania622/nya-1.jpg?t=1178914145
i want to do something like this
I guess I could take a picture of them together, but it's hard being that it's a surprise for the mom. I will try but if worse comes to worse, can someone help me put these 2 together?
http://i101.photobucke​t.com …ITATIONS.jpg?t=​1178914204 (external link)
Tania
Canon 40D, Rebel XT
17-55mm 2.8 IS, 50mm 1.8 II, 70-200 4L
28-70mm F2.4-4 DG, 70-300mm F4-5.6 DG Macro
rammy
Joined Oct 2004
May 11, 2007 15:32 |  #2
Try using the Pen Tool. It gives you more precise control. Here is a decent tutorial that can help you learn the precise control you can get with the tool:
http://www.melissaclif​ton.com/tutorial-pentool.html (external link)
You could try the Extract filter but I don't think it actually works that well.
Gear | Surrey Wedding Photographer (external link) | Surrey Wedding Photographer Blog (external link) | London Architecture Photographer (external link)
In2Photos
May 11, 2007 15:40 as a reply to  @ rammy's post |  #3
Good luck cutting out that second kid. The hair will make it very difficult. I would go for another pic if I were you.
Current Gear and Feedback
tania622
May 11, 2007 16:24 |  #4
Well I mean I wouldn't expect to get every single strand of hair... it can be trimmed... i guess...
Tania
Canon 40D, Rebel XT
Brian05
May 11, 2007 17:10 as a reply to  @ tania622's post |  #5
Well, started to have a go, but have ran out of time. Don't know if something like this is any good (you could obviously crop out the border to add your own or leave blank etc)...
5D mII | Samyang 14mm 2.8 | Canon 24-105 f/4 L IS | Canon 50mm f1.4 | Canon 85 f1.8 | Sigma 70-200 f2.8 EX DG | Canon 100 f2.8 macro | 580EX II | Metz 50 AF1 | YN568 | YN468II | YN622s
Bollan
May 11, 2007 18:48 |  #6
That looks like a job for Vertus Fluid Mask plugin. It a great plugin for doing fast and precise masking and can be found at http://www.vertustech.​com/ (external link). The offer a free trial so why don't have a go at it.
My Equestrian Gallery (external link)
My Flickr (external link)
Brian05
May 12, 2007 03:38 as a reply to  @ Bollan's post |  #7
Same pic blended a bit more into the page...
snokid
May 12, 2007 08:20 |  #8
Well this is easy, but it takes some time.
Open the channels pallet, grouped with the layers pallet.
scroll thru the different colors, ie just the red channel, then just the green channel. What you are looking for is the most contrast between the light and dark area's of what you are trying to cut out. when you find the one that looks the best, duplicate it and make sure you only have that channel selected.
Now using the dodge, and the burn tool, both set about 10-20%, turn part of the picture black and part of the picture white, don't forget you can change each tool in the options bar to work on highlights midtones or shadows. For the big area's you can just use the paintbrush to paint in the white or black.
For the picture I'm using I used two channels, I really only spent 2 or 3 minutes to get what you see here.
Now you have two ugly pictures, control click on one of the thumbnails, that loads it as a selection. turn on the rgb image, and goto the layers pallet. Click on the add layer mask icon, that will hide the area's you just selected.
a couple of things to think about using this method.
you can use levels to refine your mask.
you can soften the mask using a blur filter.
you can stack mask's on top of each other.
it's real easy to retouch your mask you haven't done anything to the original image.
you can adjust the levels of a copy of the original image to brighten or darken the channel before you go off dodging and burning.
here's a few screen captures.
feel free to ask questions if you get stuck.
Bob
IMAGE: http://farm1.static.flickr.com/221/494733899_9a6dd875fe.jpg?v=0
IMAGE: http://farm1.static.flickr.com/190/494733963_a88564fa27.jpg?v=0
IMAGE: http://farm1.static.flickr.com/190/494733827_0b8f36a686.jpg?v=0
shutterstock.com (external link)
René ­ Damkot
May 12, 2007 13:17 |  #9
Have a lookhere (external link), and look for "Advanced Background Extraction" (CS2)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
tania622
May 14, 2007 10:20 |  #10
Thanks Everyone. I received the pictures Brian, thanks a lot! =)
Tania
Canon 40D, Rebel XT
1,655 views & 0 likes for this thread, 7 members have posted to it.
2837 guests, 150 members online
