How do you get those photos where the out of focus area through use of DOF are in little circles? Is it Bokeh?
Martin
martcol Senior Member 866 posts Joined May 2002 Location: Kent, UK More info | May 07, 2004 12:01 | #1 How do you get those photos where the out of focus area through use of DOF are in little circles? Is it Bokeh? "All photographs are accurate. None of them is the truth."
roanjohn Goldmember 3,805 posts Likes: 2 Joined Dec 2003 Location: New York, NY More info | May 07, 2004 12:08 | #2 I think those circles depends on the number of blades in your aperture. More blades = more circular = smoother bokeh.
Haifidelity Member 197 posts Joined Apr 2004 More info | May 07, 2004 12:11 | #3 Big Aperture (small Aperture number), generally f/5.6 or bigger. Bokeh is the out of focus blur rendition. Specular Highlights and light sources can cause the "circles" you mentioned.
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | May 07, 2004 12:18 | #4 By using a shallow depth of field, we can manage the blur of the background. Bokeh is more of a state of mind, and it is impossible to describe technically. It is more of combination of blur and color and feeling.
justme_dc Senior Member 327 posts Joined Mar 2003 More info | May 07, 2004 12:32 | #5 martcol wrote: How do you get those photos where the out of focus area through use of DOF are in little circles? Depth of field is dependant on several things. Angle of view of the lens is important, the wider the lens the more depth of field it will have at a given aperature. Depth of field is also linked to subject distance. The closer an object is to the camera the less depth of field you will have at a given aperature. Obviously he distance from the primary subject to the backgroud effects how OOF the background will be.
SnJPhoto Senior Member 303 posts Joined Jan 2004 Location: Southern California More info | May 07, 2004 14:05 | #6 There are many DOF calculators on the web for use as well as examples. Here is one of them and some extra credit reading for you on the physics of it all.... “Half of life is f()cking up the other half is dealing with it.”
EXA1a Member 242 posts Joined Oct 2003 More info | May 07, 2004 15:58 | #7 martcol wrote: How do you get those photos where the out of focus area through use of DOF are in little circles? Is it Bokeh? Martin Maybe I'm on the wrong track but my first thought when I read your post was the doughnut-shaped bokeh. That's typical for mirror lenses and considered to be "ugly". Here is an example (scanned slide) of a Sigma 600mm/f8 mirror telephoto lens on an EOS 10:
--Jens--
justme_dc Senior Member 327 posts Joined Mar 2003 More info | May 07, 2004 17:36 | #8 Mmmm doughnuts! I love doughnuts. Especially Krispy Kremes!
| Latest registered member was a spammer, and banned as such! 2121 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
