Thread started 07 May 2004 (Friday) 21:32
Is this warranty replaceable?
vvizard
Joined Sep 2003
May 07, 2004 21:32 |  #1
Hi guys, my name is Helge, and I'm a measurebator. I joined your club tonight, to find out if my Sigma-zoom shall be sent in for replacement or not. I shot... rulers! ;) And WOW! Did I freak out when I saw my camera front-focus? Yes I did! Do you blame me? Probably not.. Anyway, here's the shots, I would like some feedback on whether this is a warranty-repair/replace issue. All shots where taken on a tripod, at f/2.8 for the Sigma, and f/1.4 for the Canon. I used centre-point AF, and placed the middle of the point over the 13cm mark, and shot with self-timer. On the later Canon-shots I even placed the finger in on where I had focused. Should've done so on the Sigma too, but anyway, It was at the 13cm mark on all shots for all lenses. The Sigma was tested @ 200mm. Both lenses had a circular polarizer filter from HOYA.
First sigma-shot. Ruler in ~ 45 degree angle
Where's focus here? 8? Off by 5cm.. not good :(
Second shot, ruler in a much more "laying" possition. Should be harder to focus correctly I think.
This test I would thought should be harder for the focus. Think focus is at 10 here.. Three off, still not good.
So now I was freaked out, thinking the camera was focusing wrong. So I mounted the 50mm f/1.4 to try that one:
~ 45 degree.
Wow! Spot on! Oh, and I did a level-correction in Gimp on this one, that's the reason why the colors are way off the rest of the shots. Shouldn't affect the test though..
Laying possition:
and spot on again...
Should I send in the Sigma for replacement?
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
May 07, 2004 23:37 |  #2
Do your focus tests WITHOUT the polarizer in better lighting...
A filter can throw off AF (in my case I had exactly the lens you have.. a Sigma 70-200mm f/2.8.. it was a perfect copy with reliable accurate focus.. but with a certain Hoyo UV filter the AF could be thrown waaaay out under certain lighting conditions...
Your test,. therefore.. is "poop" :)
CDS' HOT LINKS
vvizard
Joined Sep 2003
May 07, 2004 23:42 |  #3
Ok, thanks. My focus hunted a lot with the polarizer shooting swans in sunlight yesterday. But that was either a total bummer or as good as it use to do. But never "halfway". But I will try the test again in the afternoon without filter. Now I'm off to the racing-field. Thanks for reminding me, I'll bring the standard UV-filter for that lens if the focus-problem with the polarizer continues
KennyG
Joined Aug 2003
May 08, 2004 06:24 |  #4
Never test a lens with a filter, any filter.
Ken
Professional Motorsport Photographer
2 x 1D MK-II, 7D, 17-40L, 24-70L, 70-200 2.8L IS, 100-400L,
300 2.8L IS, 500 4.0L IS, 85 1.8, 50 1.4, 1.4 & 2.0 MK-II TC.
1,205 views & 0 likes for this thread, 3 members have posted to it.
1904 guests, 129 members online
