Look at the helmut.
Is that CA?
If so, it is the first time I've seen it in practice.
From a 30D, 70-200 f/2.8 L IS + Cannon 1.4x TC.
![]() | HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
...if so, is the TC the culprit here?
S.Horton worship my useful and insightful comments More info | May 13, 2007 22:04 | #1 Look at the helmut.
...if so, is the TC the culprit here? Sam - TF Says Ishmael
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | May 13, 2007 22:08 | #2 I think so, no idea about cause. Usually happy when there's HEAPS of light around i've found. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
May 13, 2007 22:41 | #3 No sign of it from the 100-400......... Sam - TF Says Ishmael
SgWRX Senior Member 395 posts Likes: 2 Joined Jun 2005 Location: Wi More info | it's either CA from the lens + the tc or it's bloom on the sensor. i'd be willing to bet it's CA since you're using a tc.
BillBoehme Enjoy being spanked More info | If it were CA, you would expect to see red on the other side of the helmet. It looks more like sunlight glint off the helmet and probably some flare in the lens. You would also expect to see CA anywhere there is a significant contrast boundary such as around the edges of a black object. Also, you may just be seeing a JPG artifact. Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
TeeWhy "Monkey's uncle" 10,596 posts Likes: 5 Joined Feb 2006 Location: Pasadena, CA More info | May 14, 2007 02:05 | #6 |
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | May 14, 2007 04:02 | #7 "I think the idea of art kills creativity" - Douglas Adams
May 14, 2007 08:35 | #8 Thx gang. I'll check it out more closely. Sam - TF Says Ishmael
| Latest registered member was a spammer, and banned as such! 2836 guests, 150 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
