Thread started 14 May 2007 (Monday) 20:49
Moving Plug-ins From CS2 to CS3
MDJAK
May 14, 2007 20:49 |  #1
I've attempted to go to the plug in folder in CS2, highlight and copy, for instance, NoiseNinja, then go to the plug in folder of CS3 and paste it in.
Same for pixel genius sharpener.
Neither worked. What am I doing wrong?
thanks in advance.
mark
Tsmith
Formerly known as Bluedog_XT
May 14, 2007 21:21 |  #2
Thats how I copied mine but unfortunately CS3 has totally quit working for me so I'm currently back to using CS2.
Even reinstalling won't work, piece of junk software at the moment ... :evil:
dave_bass5
Gallery: 34 photos
May 15, 2007 09:22 |  #3
You could just get PSCS3 to use the PSCS2 pluggin folder.
Dave.
Gallery@http://www.flickr.com/​photos/davebass5/ (external link)
Canon R7 | Canon EOS-M50 | Canon 24-70 f/2.8L MKII | 70-300L | 135L f/2.0 | EF-S 10-18 | 40 f/2.8 STM | 35mm f/2 IS | Canon S110 | Fuji F31FD | Canon 580EXII, 270EXII | Yongnuo YN-622C Triggers.
ssim
Joined Apr 2003
May 15, 2007 09:41 as a reply to  @ dave_bass5's post |  #4
Did you have to run an install routine when you first installed them in CS2. If you did then it is likely that you will have to do the same for CS3. I tried your solution when I upgraded and it didn't work on all of them but once I ran the install routines all was fine. When I first tried the straight copy function I got some DLL errors on the startup of CS3. After install none so I am assuming that the install routine places the appropriate dll files in the right places.
I have now started using the alternate plugin location in photoshop which makes alot of sense if you ever have to reinstall. This is purely a personal choice though but it works great and is easy to manage your plugins.
You might want to check with your software support to make sure that you don't need an update for CS3.
MDJAK
May 15, 2007 17:00 as a reply to  @ ssim's post |  #5
Thanks, everyone.
I actually emailed Seth Resnick, one of the owners/writers of PixelGenius.
He states that plugins don't yet work with CS3; that they all have to be rewritten with the binary code. They do have a beta available for downloading. I'll give that a try.
mark
1,447 views & 0 likes for this thread, 4 members have posted to it.
2923 guests, 160 members online
