Thread started 15 May 2007 (Tuesday) 07:20
Anyone try Kenko extension tubes?
cookie99
May 15, 2007 07:20 |  #1
Any feedback on these?
http://cgi.ebay.com.au …egoryZ29982QQcm​dZViewItem (external link)
Chris Cooke "Me transmitte sursum, Caledoni"
John_B
Gallery: 178 photos
May 15, 2007 07:24 |  #2
cookie99,
Kenko tubes work great, however they wont work with EF-s lenses (unless modified). :)
click to see (external link)
bungee
May 15, 2007 07:25 |  #3
I bought some from the same seller. They're well made and, since they contain no lenses, work just as well as the Canon ones (though they don't work on EF-S lenses).
The unknown is magnificent
http://www.imagine-the-world.com (external link)
cookie99
May 15, 2007 07:31 as a reply to  @ bungee's post |  #4
Thanks folks.
I Know the seller and have always had great service from him in Melbourne, I just wondered about the quality of the tubes and once again you have helped greatly.
Thank you
Twitch1977
May 15, 2007 09:49 |  #5
I've also bought from that same seller and they came fast and worked perfectly.
Kurt
http://www.flickr.com/​photos/twitch1977/ (external link)
Advice is a noun, advise is a verb.
Lester ­ Wareham
Moderator
Gallery: 3035 photos
Best ofs: 5
May 15, 2007 09:52 |  #6
I don't want to bash these as I know many are happy, but my set (new for a reputable seller) had a very loose fit and weak springs on the release buttons. This resulted in unscheduled lens dismounts, once with a very expensive lens into sand narrowly missing a marshy grave.
After that I got a set of the much more expensive Canon tubes which fit tightly and I live much happier.
I have since heard of other people with the same problem. One had the trick of covering the lens mounts (on the tubes) with sellotape to improve the lock security.
Macrophotography by LordV
tomd
May 15, 2007 09:52 |  #7
Quality is fine, no worries, go for it and post some macro shots!
Tom
=======>>> play W.A.I.N. :D
Choderboy
I like a long knob
Gallery: 185 photos
May 15, 2007 09:58 |  #8
Lester Wareham wrote in post #3209090 (external link)
Also happened to me.
Twice I realised that I had managed to inadvertently release the lens.
I am yet to work out if I am doing something stupid or heavy handed to cause this, but I have never had the same problem with my Canon TC , with release lever positioned in a similar place.
Dave
Image editing OK
Billginthekeys
Billy the kid
Joined Nov 2005
May 15, 2007 10:06 |  #9
they work fine, especially for the price. yes some people have managed to slide their hand across the release button, but as long as you are careful i dont see why you should tons more for canon's tubes.
Mr. the Kid.
Go Canes!
My Gallery (external link)My Gear
what the L. just go for it.
Reptile ­ Bob
May 15, 2007 11:42 |  #10
I'm very happy with my extension tubes. I'm very abusive to my equipment (good thing I have a great personal property insurance company), but haven't had any problems. They practically live on my 100mm macro, but they've done well on the 70-200 for butterfly or dragonfly shots.
My copy seems to fit quite snugly together. Even if the release is accidentally pressed, it would take a good twist to remove the lens or separate the tube set. I haven't had any accidents yet.
Good luck!
Robert
All Canon: 350D / 5D / 50mm 1.8 / 10-22mm / 100mm 2.8 Macro / MP-E 65mm Macro /
24-105 4L IS / 70-200 2.8L IS / 2x T-con / 580 Ex Flash (2)
Other Stuff: Slingshot 300 / Stealth Reporter 650 / Extension tube set / a few sigmas :rolleyes:
http://community.websh​ots.com/user/wwwplants (external link)
http://s95.photobucket​.com …ptilebob/Macro/​?start=all (external link)
Lester ­ Wareham
Moderator
Best ofs: 5
May 15, 2007 13:10 |  #11
Choderboy wrote in post #3209112 (external link)
There were two problems compared to the Canon ones that contributed in my case, other respondents have reported the same issues.
a) Weak release button springs
b) Zero lock and unlock torque
The result was any small force on the release buttons and the lens could just rotate a little becoming unlocked. It would then rotate all the way to fall off when is use or being carried.
The original thread is here https://photography-on-the.net/forum/showthre​ad.php?t=186161
By contrast the Canon tubes have release button springs that are much stronger and require more lock and unlock barrel torque than the teleconvertors.
S.Horton
May 15, 2007 13:27 |  #12
John_B wrote in post #3208537 (external link)
cookie99,
Ditto. Didn't know you could modify them, though. Tubes are just tubes, picking a name brand, I'm told, won't make a difference to a casual macro user such as myself.
EDIT: Ok, Look above ^^^^^^^^ holy sugar that could matter!
Sam - TF Says Ishmael
:cool:
mrclark321
Noinker
May 15, 2007 13:38 |  #13
Mine work greta and the fit is tight :)
Lester amybe you got a lemon.....Lot's of Canon lemons out there too!
Sony A7R3 & A7R4
Sony 16-35 GM
Sony 55mm 1.8
Batis 85mm
Sony 200-600
Lester ­ Wareham
Moderator
Best ofs: 5
May 15, 2007 14:14 |  #14
mrclark321 wrote in post #3210163 (external link)
Quite possibly, there are a few other with the same type of fruit also, but I freely admit that it must be a small minority as so many are happy with the Kenkos.
Really I feel it is worth warning folk, if you don't have to make a noticeable effort twisting the lens on watch out.
I could have sent them back asked for replacements etc but having had my 300 f4 IS just miss dropping in water and instead getting the inside full of sand was enough for me - order the Canons and be done with it. It is just not worth fannying around to save a few pounds with that level of potential loss. ;)
Greg_C
Gallery: 10 photos
Joined Nov 2005
May 15, 2007 15:18 |  #15
My Kenko tubes are a very tight fit. Never had any problems with them.
Greg
Blog (external link) | Photogallery (external link) | 1DmkIV + other stuff
Sanity is a madness put to good use.
2,672 views & 0 likes for this thread, 15 members have posted to it.
919 guests, 109 members online
