Thread started 17 May 2007 (Thursday) 14:07
What the best can Noise Ninja bring?
Galaxy99
May 17, 2007 14:07 |  #1
I have a NN independent version installed. Also I am using a CS2/3. I heard so much good thing from NN to bring Noise down, but I never can excute it as it is said from others. I feel like it is less effective than CS2/3-noise program (medan, etc...). It doens't suppose to be that way, does it? The help with NN is so simple and helpless.
Can anyone tell me what your NN setting is to able to maxiumize the noise remove effect or how to intensively use NN to remove noise?
Thank you.
milleker
Joined Feb 2006
May 17, 2007 21:29 |  #2
My settings are mostly different, I always profile my image (on the first page of the plugin, not sure about standalone). They even make profiles for your brand/model of digital camera - available on their site.
Love NN, don't know what I'd do without it! Maybe go back to film? Naaah.
---John Milleker Jr.--
Web Links: My Homepage (external link)
Photography Weblog (external link)Flickr (external link)Maryland POTN Meetup Thread (external link)Donate to POTN! (external link)http://www.johnmilleke​r.com/weblog (external link)
cdifoto
Don't get pissy with me
May 17, 2007 21:31 |  #3
Galaxy99 wrote in post #3222104 (external link)
I'm dumb and/or lazy so I auto-profile each image. There is no single miracle setting for all pics.
poloman
May 17, 2007 21:47 |  #4
Noise Ninja has provision for taking screen shots at different ISO's with your particular camera. The image is provided on their disk and directions are in the help file. Take a couple hours to do it once and you will be able to automate much of your use of the program. Of course you can always profile the image and then tweak the result if you desire.
"All those who believe in psychokinesis, raise my right hand!" Steven Wright
Montec
May 17, 2007 22:45 |  #5
A good tip is to create a separate layer and apply NN. Go overboard.
Then use a layer mask to adjust to your liking. Alternatively you can adjust the opacity of the NN layer to get the effect you want.
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
May 17, 2007 23:08 |  #6
My choice, too. Some help with layer masks:
Airport runway shoot
Layer Mask video tutorials
http://www.heathrowe.c​om/tuts/layerthumbs.as​p (external link)
Adjustment layer basics (external link)
Galaxy99
May 21, 2007 16:19 |  #7
Thanks a lot, guys. I only understand to shift the luminance bars and sharping bars... If so, why don't I just use CS2 instead...
I see on top menu, you can choose each color channel, I assume you can reduce noise from each individual channel... How can I do that? Maybe I need to learn how to set up layer and layer mask first...
Montec
May 21, 2007 17:02 |  #8
Don't mean to ni-pic but there is a rather obvious typo in your sig...thought you may want to know
Cheers!
I dream to have Mark III with bunch of Ls. The dream will be filfulled sooner than I think...
The sample photo below is using NN on a very grainy photo taken in very low light at 1600 ISO. It does an amazing job in my opinion, just play around with the settings.
Galaxy99
May 21, 2007 17:10 |  #9
sig error noted. thanks. Wow, I can't tell image was shoot at iso1600. That's what NN seems to be.
Noticeable change in noise reduction is to reduce contrast under Luminance and of course two bars under sharpening.... Is that all I can do with NN?
J ­ Rabin
Joined Aug 2004
May 22, 2007 07:56 as a reply to  @ Galaxy99's post |  #10
Galaxy:
I get fine results with Noise Ninja meeting my expectations printing up to 8x10" from ISO 1600 Canon RAW files. All these NR tools work if you understand them to tweak the defaults. Here is my own NN Workflow, maybe this will help you: http://postit.rutgers.​edu …5FCanonRAW%5FWo​rkflow.pdf (external link)
I doubt they have posted a 400D Profile, so you'll just have to make your own selection patches.
Hope this helps you get the results you want. Jack
PhotosGuy
Joined Feb 2004
May 22, 2007 09:17 |  #11
Good job!
J ­ Rabin
Joined Aug 2004
May 22, 2007 09:35 as a reply to  @ PhotosGuy's post |  #12
Thanks PhotosGuy Frank.
I just did a martial arts tourny. Shot 440 at ISO 1600 and f/2.8. Had 110 keepers (25% keepers is very high for me). Ran them through a tweaked NN profile as I described in attachment. Print quality elcited ooohs and ahhhs from customers (many parents who had dSLRs). So, I know it works.
You are scaring me though - how does one accumulate 20,000 posts?
Jack
Galaxy99
May 22, 2007 13:38 |  #13
Wow, Rabin Jack. Thanks for the tutorial! Print it out and post it by my monitor... Thanks a bunch.
Don ­ Powell
Joined Nov 2005
May 22, 2007 15:57 as a reply to  @ Galaxy99's post |  #14
Thanks for your post. I too, have had poor results using NN. My images were always too soft after using NN. It looks like I need to study some and try again. I try very hard not to get much noise, but noise is inevitable.
Best wishes, Don
In2Photos
May 22, 2007 16:03 as a reply to  @ Don Powell's post |  #15
I bought NN when I first began my Photoshop processing. I would use it all the time. But then I stopped using it when I figured out that I was too anal about the noise. How bad is the noise you guys are getting? When do you get the noise? Are we talking ISO 1600 or ISO 200? I have yet to use NN in about a year. One thing that helped was I began to slightly overexpose my shots (around 1/3 of a stop) and consistantly check my histogram to make sure I was ETTR (exposing to the right).
Current Gear and Feedback
2,332 views & 0 likes for this thread, 12 members have posted to it.
2867 guests, 140 members online
