I am trying to clean up the computer a little but for some reason it is saying it doesn't recognize the cr2 files. Any ideas on what I need to do? Didn't know there would be any problem putting RAW files on a DVD...EricL
EricL Senior Member 692 posts Joined Nov 2006 Location: Anchorage, Alaska More info | May 17, 2007 20:39 | #1 I am trying to clean up the computer a little but for some reason it is saying it doesn't recognize the cr2 files. Any ideas on what I need to do? Didn't know there would be any problem putting RAW files on a DVD...EricL [SIZE=2]
lostdoggy King Duffus 4,787 posts Joined Aug 2004 Location: Queens, NY More info | May 17, 2007 20:44 | #2 That is strange because I burn them on a regular basis.
glhs509 Goldmember 3,925 posts Likes: 28 Joined Jul 2006 Location: Chicago More info | What software (and mode/option) are you using for burning? ~Ken
I am running Widows XP Professional. I have tried several different avenues: Windows Media Player, Roxio Digital/Media Player, dragging and dropping. Nothing seems to be working. I have also tried doing non RAW pics with no luck either. EricL [SIZE=2]
lostdoggy King Duffus 4,787 posts Joined Aug 2004 Location: Queens, NY More info | May 17, 2007 22:01 | #5 Windows don't do RAW unless you have the Windows RAW viewer and if you do then that might be the problem. I tried Windows RAW viewer and it won't let me delete or move the RAW files and also prompting me that the file is in use. After uninstalling it it went away. Now what burning S/W are you using to burn DVD w/. I use Nero Ultra Edition and I don't have a problem. I've never used Windows builtin S/W to burn DVD but have used it to burn CDRs. I don't believe Windows Builtin burning S/W supports DVDs.
glhs509 Goldmember 3,925 posts Likes: 28 Joined Jul 2006 Location: Chicago More info | Sorry I don't have any experience burning with those apps. I personally prefer dedicated burning software, such as Nero or Easy CD/DVD creator. ~Ken
PhotosGuy Cream of the Crop, R.I.P. More info | May 17, 2007 23:10 | #7 Whichever method you use, you should be burning "data" CD/DVDs, That's probably the problem. FrankC - 20D, RAW, Manual everything...
kevin_c Cream of the Crop 5,745 posts Likes: 4 Joined Mar 2005 Location: Devon, England More info | May 18, 2007 09:01 | #8 As far as I know Windows XP does not natively support burning to DVD, only to CD - You will need to use a program like Nero for this and as others have said you need to burn a Data DVD. -- K e v i n --
csm328 Goldmember 1,834 posts Likes: 2 Joined Jan 2007 Location: Canberra, Australia More info | May 18, 2007 09:12 | #9 If you have LR then you can export as a 'burn' to DVD/CD but, in any case, it should be data. If you have PS then try viewing your files in Bridge first then exporting etc etc. Shouldnt be a big deal at all. Wayne
Thanks guys for the info. It was the fact I wasn't doing it under "data". Working great now!! Thanks again. EricL [SIZE=2]
| Latest registered member was a spammer, and banned as such! 2814 guests, 164 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
