Hi all,
I have a simple Q, how do you use the fill flash in the 300D.
aam1234 Goldmember 4,132 posts Likes: 1 Joined May 2004 More info | May 11, 2004 03:16 | #1 Hi all,
May 11, 2004 09:32 | #2 I mean how do you make the flash fire when there is a lot of light.
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | May 11, 2004 09:50 | #3 You _did_ read the manual, didn't you?
Jim_T Goldmember 3,312 posts Likes: 115 Joined Nov 2003 Location: Woodlands, MB, Canada More info | May 11, 2004 09:50 | #4 Don't use the programmed modes (auto, landscape, sports etc). You aren't allowed to override any camera settings.. The camera is in complete and total control.
ecobo Senior Member 580 posts Likes: 6 Joined Feb 2004 Location: Bulgaria More info | May 11, 2004 09:59 | #5 Use <P> only. This is a recommendation in the 300D user's manual.
tpinchback Senior Member 657 posts Likes: 2 Joined Jan 2004 Location: Houston More info | May 11, 2004 11:16 | #6 Download the Russian firmaware hack to your camera. 1D MKIII 5D MKII
DieselGirl Senior Member 270 posts Joined Apr 2004 More info | May 11, 2004 11:17 | #7 tpinchback wrote: Download the Russian firmaware hack to your camera. Set the camera to P mode Open flash FEC +2 stops Your warrenty is now VOID, but, you have a fill flash. yippee
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | May 11, 2004 11:56 | #8 And just for clarification, if you are going to be using the internal (built-in) flash, the shutter won't go after than 1/200. If you need a shutter speed fater that that, you'll need to use an external flash (which has highspeed sync capability) set to highspeed sync. ...Leo
scottbergerphoto Cream of the Crop 5,429 posts Likes: 1 Joined Jun 2003 Location: Brooklyn, NY, USA More info | May 12, 2004 06:04 | #9 tpinchback wrote: Download the Russian firmaware hack to your camera. Set the camera to P mode Open flash FEC +2 stops Your warrenty is now VOID, but, you have a fill flash. Fill Flash is meant to fill in shadows created by uneven lighting on a sunny day or add some light to shade. As such, you want it to be less then the ambient lighting levels. You are not using it to light the subject, just add some fill. FEC for fill flash should be -1 to -1and 2/3, not " +" (unless this is something idiosyncratic to the Russian firmware). One World, One Voice Against Terror,
BruceHamilton Goldmember 1,404 posts Likes: 1 Joined Feb 2004 Location: USA More info | May 12, 2004 07:33 | #10 DieselGirl wrote: tpinchback wrote: Download the Russian firmaware hack to your camera. Set the camera to P mode Open flash FEC +2 stops Your warrenty is now VOID, but, you have a fill flash. yippee Actually, it's whoopie...
| Latest registered member was a spammer, and banned as such! 1901 guests, 129 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
