Thread started 11 May 2004 (Tuesday) 13:22
DRebel, Russian firmware, FEC in Av mode
yb98
Joined Feb 2003
May 11, 2004 13:22 |  #1
I just noticed that with the russian firmware, the FEC don't work in Av mode... Have you noticed the same thing ?
Yacine.
Best DPP Threads
DPP++ Video Channel (external link)
New Version DPP++ 11.3 released (external link)
EXA1a
Joined Oct 2003
May 11, 2004 13:37 |  #2
Yacine.
Av mode is the mode I normally use with flash. Here is a quick test. It works perfectly with my camera and on-board flash, Av f8.0.
FEC -2, 0, +2
IMAGE: http://www.bidencap.de/FEC_Av_300D.jpg
Under which conditions do you have problems?
--Jens--
tpinchback
Joined Jan 2004
May 11, 2004 13:43 |  #3
i did notice a difference from 0 to +2 but, not -2 to 0. other than that it is all fine and dandy.
1D MKIII 5D MKII
Glass ranging from 16mm to 400mm
EXA1a
Joined Oct 2003
May 11, 2004 13:58 |  #4
Looks like
either the flash fires full blast anyway, so FEC plus something cannot increase the flash intensity,
or the flash fires at its lowest output, so FEC minus something cannot further decrease the output.
--Jens--
yb98
Joined Feb 2003
May 11, 2004 14:11 |  #5
hmm... after some test I just did, for me there is a difference between -2 to 0 and no difference between 0 to +2....
Best DPP Threads
Guillermo ­ Freige
Joined Jun 2003
May 11, 2004 15:49 |  #6
Increase the ISO 2 stops (from 100 to 400 for example) and repeat the test. Probably the flash is already using the full blast at 0.
Guillermo
EOS 5D MkII, 40D and 20D owner.
EF 17-40L, 24-105L IS , 70-300 IS, 24 f2.8, 35 f2, 50 f2.5 Macro, 85 f1.8.
EF-s 18-55 IS. Sigma 12-24, Tamron 17-50 Di II
1,630 views & 0 likes for this thread, 4 members have posted to it.
1901 guests, 129 members online
