Here is my first attempt at using fill flash. Im really having trouble understanding how I meter for the background and get good exposure on the background and subject (i.e. a couple at sunset).
Im using a 30D w/580 EX II.
I use Av mode set at f/8-f/11 and the shutter automatically goes to 1/250 as per the custom function or Tv mode shutter set to 1/200-1/250, flash set to ETTL both ISO 100
With these settings how can I meter the background if my shutter wont go higher than 1/250, in the daytime and at night to expose for the sky I would think something like 1/500-1/1000. So how can I or better yet is it a good idea to change the custom function so I can use higher shutter speeds with fill flash.
Finally why does the flash recharge instantly at times then other times take 1.5 sec?
Few shots for example, I had to use PS to saturate the skies the sun was bright but I think these turned out ok.
