Thread started 20 May 2007 (Sunday) 20:53
Help with B&W conversion using Lightroom?
Curtis ­ N
Master Flasher
May 20, 2007 20:53 |  #1
I took a bunch of headshots for an actor who needs B&W 8x10s for auditions. I've never done B&W before - I'm just a color kinda guy so I'm a little clueless in this area.
Here is the color version (converted from RAW), followed by what Lightroom's "Grayscale Conversion" preset gave me. I notice it dropped the color temp, used some highlight recovery (though there was nothing blown in the original) and raised the black point, cranked up the contrast but made the tone curve flat. It also used a variety of settings in the Grayscale mix. None of these settings are identical in all shots, but similar.
I'm not thrilled with this conversion, but a) I really don't know why, and b) I wouldn't have a clue how to improve it.
If anyone can advise how to better use Lightroom for B&W portraits, I would greatly appreciate it.
moree
Joined Nov 2005
May 20, 2007 21:34 |  #2
Hi Curtis N,
Have you tried the presets available from http://www.ononesoftwa​re.com/photopresets-wow.php (external link)
these are free and will make it easy to see quickly a few different edits in B&W. I was going to post a quick example however I didn't see that image editing was OK so have left it alone.
Alternaively you could play with the grey scale mix in Lightroom. I hope this has been of some help.
Nicholas
Tony-S
May 20, 2007 21:53 |  #3
Curtis,
Does Lightroom have a channel mixer? If so, try setting it to monochrome with red at 60%, green at 40% and blue at 0%. You may want to adjust the green up or down a bit to suit the skin tones (remember B&W film with green filters?), but make sure you end up wiht 100%.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
cdifoto
Don't get pissy with me
May 20, 2007 21:58 |  #4
I've been using a B&W conversion called Black & White - Old 1 that I downloaded from www.lightroompresets.c​om (external link) that I really like. It increases exposure, so if your images are already dark they'll get too light. For that reason I made another version of it that doesn't affect the exposure and saved it as another preset. I think all "grayscale" conversions suck.
Curtis ­ N
Master Flasher
May 21, 2007 05:26 |  #5
Moree & CDI, thanks for the links, I'll take a look. Sorry I forgot to turn on my image editing OK option. That's been fixed.
Tony, here's what Lightroom's channel mixer looks like The sliders go from -100 to +100. These are the settings used by the Greyscale conversion preset on the image above. I'll do some playing with it.
Thanks all for the tips!
EOSAddict
Book Committee Immortal
May 21, 2007 06:28 |  #6
Curtis,
I think that the LR default conversion is meant to be fairly benign. But to get decent B&W shots you will need to have aplay with the sliders..... try pushing the green and/or red towards the extremes and see.... imagine the effect like B&W filters on a film camera...
Al
My Gear, My Website: www.endofthetrailphoto​graphy.com (external link)
flashtoby
May 21, 2007 06:38 |  #7
Heres my quick attempt done in lightroom.
In2Photos
May 21, 2007 07:45 |  #8
Curtis, check out these presets for B&W as well:
http://inside-lightroom.com/bw.php (external link)
I tried my hand at some of my own but found that I can usually get something I like better from these presets.
Current Gear and Feedback
Curtis ­ N
Master Flasher
May 21, 2007 08:37 |  #9
flashtoby wrote in post #3240464 (external link)
Thanks.
I like it, at least I like it more than my own version, but it does me no good unless you tell me what you did.
Curtis ­ N
Master Flasher
May 21, 2007 08:40 |  #10
EOSAddict wrote in post #3240429 (external link)
I can imagine it, I just don't know how to produce it. :confused:
If I had ever used B&W filters with film, I might have some idea what they did.
I'll play with the sliders some.
1,568 views & 0 likes for this thread, 7 members have posted to it.
2903 guests, 169 members online
