Hmm. The battery from my 350D went through the washing machine. Obviously I'm drying it out but does anyone have any idea if the soaking will render it useless or, worse, prone to damage my camera?
TimSewell Member 115 posts Joined Oct 2005 Location: Hove, UK More info | May 22, 2007 10:35 | #1 Hmm. The battery from my 350D went through the washing machine. Obviously I'm drying it out but does anyone have any idea if the soaking will render it useless or, worse, prone to damage my camera?
wbessada Senior Member 505 posts Joined Jan 2005 More info | May 22, 2007 11:39 | #2 My concern would be water that would have got to the inside of the casing and may rust the terminals. UK - Brand new Sterlingtek Batteries for sale here
wazmunstr Senior Member 974 posts Likes: 98 Joined Feb 2006 Location: Sarasota, FL & Chattanooga, TN USA More info | May 22, 2007 15:21 | #3 dont trust it. im sure water got inside the battery. so its either completely dead, or may fry some stuff when you put it in your camera.
BigWIll "Slight breach of etiquette" 2,363 posts Likes: 1 Joined Oct 2005 Location: Chester & Bucks UK More info | May 22, 2007 15:26 | #4 Can you not test it using a volt/current meter etc? Computers blur the boundaries... We are being released from the suddenness of photography, the suddenness of the shutterhttp://www.photography-on-the.net …p?p=1606920&postcount=132
May 22, 2007 19:45 | #5 Let it dry out. It will probably be OK. Place it so that it will drain. Be patient and verify it is dry before puting it in your camera. Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
jaisai01 Senior Member 277 posts Joined Oct 2004 More info | let it sit for atleast 24-48 hrs, and use a voltmeter to have it checked..... and then if it checks well, charge it . and if it doesnt fry on the charger you should be good Canon 5D/ BG-E4 Grip /Canon 20d / BG-E2 Grip / 18-55mm kit / 28-135mm IS / 50mm f1.8 / 70-200f4L / 24-105f4L IS/ 550ex Flash / 420ex Flash (on umbrella) / all packed in a Pelican 1510 w/ Dividers & Photographic Organizer
rklepper Dignity-Esteem-Compassion 9,019 posts Gallery: 2 photos Likes: 14 Joined Dec 2003 Location: No longer living at the center of the known universe, moved just slightly to the right. Iowa, USA. More info | May 22, 2007 20:23 | #7 Is it really worth taking the chance? I would replace it. Doc Klepper in the USA
Grentz Goldmember 2,874 posts Joined Apr 2007 Location: Midwest, USA More info | May 22, 2007 20:25 | #8 If you have other batteries that can get you by for a bit I would just buy a new one. They are only around $15-$20 (or less) to buy third party batteries from eBay and such. Search.TechIslands.com
r.morales Goldmember 2,296 posts Joined Apr 2007 Location: Bay Area Calif More info | May 23, 2007 15:45 | #9 I would toss it . It may work forever but it's more likely to
b1gdaddy Senior Member 348 posts Likes: 4 Joined Jul 2005 Location: Liverpool, UK More info | Sack the wife for putting it through the washer in the 1st place
| Latest registered member is ANebinger 1061 guests, 174 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
