Thread started 22 May 2007 (Tuesday) 23:16
Batch rename when shooting with 2 cameras
Digitalwave
May 22, 2007 23:16 |  #1
How do you guys handle the fact that when you shoot with 2 cameras, the file names are non-sequential? I have images starting at IMG_41xx and then images starting at IMG_95xx from my second body. I shot both throughout the whole wedding, so I don't want the couple to go through all the pictures from the first body only to discover the the wedding day has suddenly started over when the second body's photos come in!
I see there is a batch rename feature in Adobe Bridge but the other issue I face is that one of the camera bodies didn't have the time stamp set properly so I can't chronologically rename the files either. Is there any way to modify the last modified date so I could do it in bridge? I basically want it so both sets of images display the events of the wedding in the correct order without going through all of camera one before you see any of camera two.
bcbenson2
May 22, 2007 23:27 |  #2
I had the same issue last year when I went on a road trip and I had two cameras that times were set different, and then one was changed mid way through the trip, and it had to potential to get really really messy. I was able to find a program called Exifer that allows you to batch adjust the exif data of an image, such that you can add or subtract time to the time the shot was taken data. Just find two images that were taken at the same time with the two cameras and find out the time difference.
Here is a link to the software :
http://www.exifer.frie​demann.info/ (external link)
Then In windows you can set it too details view, set it to show the "time shot taken" detail, and order it according to that
Brian
www.BensonPV.com (external link)
www.Robotic-Hobbies.com (external link)
Canon 30D |EF 100-400 mm L | EF 28mm f/1.8 | EF 28-135mm f/3.5 IS | EF 75-300mm f/4.5 III | EF-S 18-55mm f/3.5 | 550EX | 420EX
Digitalwave
May 22, 2007 23:37 as a reply to  @ bcbenson2's post |  #3
Outstanding! Exactly what I was looking for. Thank you so much.
tim
Light Bringer
May 23, 2007 02:24 |  #4
That's definitely the hard way to do things. My wedding FAQ covers this, or my wedding workflow. Basically sync your camera times, sort the images by date taken, then rename so the filenames are sequential. DIM (see links below) can help out too.
mmahoney
May 23, 2007 05:01 |  #5
If you use the Canon software to download then it automatically puts a "_1" and "_2", etc. in the file to avoid confusion. For example if one file named "IMG_3400.CR2" has already been downloaded and you download another file with the exact same name to the same folder then the software will automatically rename the second file "IMG_3400_1.CR2".
Mike
Newfoundland Wedding Photographer (external link)
Digitalwave
May 23, 2007 07:25 |  #6
tim wrote in post #3251990 (external link)
Well, it has already happened so I can't sync them now. I will for next time but it can't help last week's wedding.
mmahoney wrote in post #3252248 (external link)
Mike
The files are different, as I said one starts at IMG_41xx and the other at IMG_95xx.
Stooge_UK
Joined Nov 2003
May 23, 2007 07:34 |  #7
If you have lightroom you can chnage the times as well. Has a number of options to do it...
You can chnage a lot of them at once, especilly if out by a time zone setting...
(been there, done that a few times....)
Stu
Stooge
Taking life one frame at a time :)
http://www.goodwayphot​ography.co.uk (external link)
RobKirkwood
May 23, 2007 07:50 |  #8
Digitalwave wrote in post #3252667 (external link)
Breeze Browser Pro allows you to adjust image file timestamps after the fact ...and their Downloader Pro recognises camera serial numbers and will automatically change or add to filenames based on this during download (e.g. 20D1_imgXXXX, 20D2_imgXXXX, 20D3_imgXXXX, etc.) - once setup you don't need to even think about it.
Rob
Yella ­ Fella
May 23, 2007 09:05 |  #9
just a thought, i not changed my summer times yet :o
Ed - www.edwardlui.co.uk (external link) | modelmayhem (external link) | facebook (external link)
Canon EOS 5D x2 | Canon EF 35mm f1.4 L USM | Canon EF 50mm f1.2 L USM | Canon EF 85mm f1.2 mkII L USM | Canon EF 24-70mm f2.8 L USM | Canon EF 70-200mm f2.8 IS L USM |Canon 580EX mkII x2http://www.edwardlui.c​om (external link)
Toogy
"I like pictures of myself!"
Joined Nov 2003
May 23, 2007 09:45 |  #10
I use breesebrowser to rename all files based on timestamp. And if the timestamp on one camera is out of whack, breesebrowser can batch adjust that as well.
Good Light and Shoot to the Right....
samckitt
Joined Apr 2004
May 23, 2007 10:52 |  #11
I make sure the cameras times are the same & then sort them by time in Photoshop Bridge. There is a batch rename function in Bridge. The last wedding we did, one camera one an hour off from the other. So that made it a little difficult. I found an exif tool that will change the time. I had to do that first & then do the rename. Fun fun fun.
Scot
Canon 30D | Canon 10D | EF 24-70 2.8L | EF 70-200 2.8L IS | EF 28-135 3.5-5.6 IS | 550EX | 580EX | BG-ED3 | BG-E2
jessiper
EEK! I don't want a title anymore!
May 23, 2007 12:40 |  #12
Anything you can do in CS3?
*Gear: 5D Mark II, 2 5D's, 30D, 85mm 1.8, 50mm 1.4, 24mmL 1.4, 45mm TS-E, 16-35mmL 2.8 II, 70-200L 2.8 IS, 100mm 2.8 macro, 15mm 2.8 fisheye, 580EXII, 580EX, 430EX, AB 800, AB Ring flash, lots of PW's, stands, umbrellas, etc.
Oregon wedding photographer (external link)
lil_miss
May 23, 2007 15:28 |  #13
My hubby as written a small file that searches the dates (provided they're in synch time wise with each other) and then renames them to whatever you please.... it also orders the Raws (as I shoot raw and small jpg), and puts them in a different folder while retaining the same new name for each image... :D
A bunch of Canon bits and pieces.
Blog (external link) :: Facebook (external link)
Digitalwave
May 23, 2007 16:17 |  #14
Does Exifer let you modify the dates by batch instead of doing them one at a time? I haven't downloaded it yet, still at work...
moviemaker
May 23, 2007 23:36 |  #15
I agree with Tim. It's what I do. Sync the time and sort by date image taken (Provided, that the image numbers don't overlap (Same IMG_xxxx file name))
|| 5D || Canon 70-200 USM IS L || Another 5D || 28-105 USM || Tamron 70-300 || Sigma 70-200 || 2x Converter || Extension tubes || 580EX || 550EX || Canon 15mm Fisheye || Canon CP-E4 || Lowepro AW CompuTrekker ||
5,730 views & 0 likes for this thread, 12 members have posted to it.
1044 guests, 107 members online
