Thread started 15 May 2004 (Saturday) 11:30
How should I post process this?
MrChevy
Joined Jan 2003
May 15, 2004 11:30 |  #1
This is right out of the camera, just resized and posted. How can I improve it with post processing? It is a photo of my wife Ani. She commented it doesn't "POP". How do I make it do that? I am trying to learn how to use Photoshop. Yes, I see the lipstick on her teeth. Is it too soft?
Thanks,
Ken
EXIF info:
2003:12:06 15:47:19
70.0-200.0mm @ 200.0mm
Subject dist: 5.83m
1/200 sec, f/2.8
Mode: Av
Metering: Evaluative
ISO: 100
AF mode: One-shot AF
Drive: Continuous: frame 1
IMAGE: http://home.comcast.net/~kenchevy/CRW_1316w.jpg
White balance: Auto
Flash: External E-TTL + Red eye reduction
File size: 97KB
Image size: 505 x 654
Color space: AdobeRGB
Saturation: Normal
Sharpness: Normal
Contrast: Normal
Tone: Normal
Ken
Ken Chevy
http://MrChevy.com (external link)
WinXP w/PS CS for editing, Ati All-in-Wonder 9600, LaCie electron22blueIV, LaCie electron19blueIV, MonicoEZcolor w/OPTIX for profiling the monitors.
Feel free to edit my photos to show an alternate treatment is Ok as long as they are re-posted in their original thread. Most of us are here to learn!
Canon owner/shooter since 02/1967
Bruce ­ Hamilton
Joined Feb 2004
May 15, 2004 14:44 |  #2
I'd start by lightening the background, too much contrast with her dark hair. :wink:
MrChevy
Joined Jan 2003
May 15, 2004 14:46 |  #3
Go ahead and download it and change it and re-upload so we can see how it is done please.
Thanks Bruce.
Ken
Ken Chevy
Bruce ­ Hamilton
Joined Feb 2004
May 15, 2004 15:30 |  #4
xx
MrChevy
Joined Jan 2003
May 15, 2004 16:46 |  #5
MrChevy wrote:
Go ahead and download it and change it and re-upload...
What I did was adjust the fill flash +1, then used auto levels to finish it off. I didn't touch the lipstick smudge on her teeth, I'll leave that for you. ;)
Do not lighten the whole photo. :oops: :oops: Just lighten the background. Her skill color is correct, her sweater color is correct, her hair IS that black :wink:
I can't seem to mask quickly worth a damn, that is why I don't try doing that yet :x Someday I hope to be able too if I keep at it. An ugly job of me doing that (what you said: lighten the background) is here: [I only lightened ½ of the background so you can see I didn't lighten the whole photo]
IMAGE: http://home.comcast.net/~kenchevy/CRW_1316w2.jpg
but notice how bad it looks, where her hair separates from the background looks BAD, and I even missed some down by her shoulder.
But notice, you have to leave everything in the photo but the background untouched, all of the rest of the colors are fine.
Ok Bruce, and anyone else, let's see the background lightened and re-uploaded. :D :D
And Bruce, DO try again, it is the way we all learn, by trying different things. :)
And YOU are lucky you weren't close by when Ani saw your 1st try at it :D:D Her quote: "My skin does NOT look like that" ... but I calmed her :twisted: down, so try again.
Ken
Ken Chevy
karusel
Joined Nov 2003
May 15, 2004 17:44 |  #6
Um... I'm kind of bothered by the too aggressive lip color it just doesn't go with her, but you can change that easily... also whiten the teeth a little bit and remove the what seems like wrinkes under lower lip. I would not say that original background is a problem.
5D and holy trinity of primes. Now the 90mm TS-E TS-E fly bit me. I hate these forums.
Don ­ Ellis
Joined Sep 2001
May 19, 2004 03:27 |  #7
Hi Ken,
I wouldn't done anything except that you asked... and I'll preface any change with a disclaimer that we all have our own tastes and approaches. Ani is lovely (and she can cook and photograph), so any improvement in this photo is bound to be minor.
Here's my version...
IMAGE: http://www.kleptography.com/dl/fm/ani3.jpg
... and what I did...
1. I don't know Ani's skin color but I have a feeling it's not quite as red as the original photo, so I used a classic S-curve in Curves to lighten the highlights and darken the shadows slightly ("slightly" being very important). Alternatively, you can go to Hue/Saturation, set the mode to Reds and lower the Saturation slightly. Either way, the S-curve is important to increase contrast and offset Light Ani from Dark Background.
2. Then I sharpened her... I tend to make things pop by pushing sharpening to the limits. In this case I used Ultrasharp Quick Sharp 50, which sharpens detail and leave areas of no detail (the background in this case) untouched. Alternatively, you can use Photoshop's Unsharp Mask at 150, 0.3, 0 and then again at 120, 0.2, 0.
3. Flattened the layer and used the Sharpen Tool at 12% and clicked twice on the highlights in her eyes. (Which you won't have to do if you're using Unsharp Mask by itself, as above.)
4. Cropped off a bit of the top and left side so that she's more centered and the white feather on the left is cut away.
5. Used a 125-pixel Burn Tool (Midtones at 50%) set at maximum dispersion and then darkened what little white remains on the left-hand side and top-left corner.
And there you are. Again, skin tones might not be right.
Personally, I wouldn't worry about her teeth. They're beautiful and natural and this isn't Vogue... it's a real-person photo.
Having said that, you can select them if you want (I use Quick Mask and a brush to select them), call up Hue/Saturation. Select Yellows and reduce Saturation to -70 or so, and then select Master and bump the Lightness to 10 (as I said, minimal). You'll get this...
IMAGE: http://www.kleptography.com/dl/fm/ani4.jpg
The best way to look at the changes for me is not side-by-side, but to use ACDSee Classic, make one photo full-screen and then use PgDn and PgUp to switch back and forth between two photos. Details that have changed will be immediately apparent, unlike viewing both photos at the same time.
Anyway, there's one man's opinion. It's mainly the more aggressive sharpening that works for me in this photo. The eyes now pull you in which they didn't before.
Cheers to you both,
Don
P.S. I'm happy with the original darker background, but her she is against a slightly lighter background...
IMAGE: http://www.kleptography.com/dl/fm/ani6.jpg
mvrekum
Joined Jan 2004
May 19, 2004 05:41 |  #8
Just a simple retouch:
Use the 'magic wand tool' in photoshop to select the background (set it to 4 and use the shift key to make multiple selections)
Use the 'lasso tool' + shift key to select remaining bits or alt key to deselect parts.
Open curves. set the cross in the middle (127/127) and use the arrow keys to move the point up or down.
If the image is to your likings, click ok.
That's all, 5 minutes work.
Martin
www.martinvanrekum.com (external link)
EOS 350D :: EOS 5 :: Powershot A70
EF 24-70 L :: EF 70-200 L IS :: EF 28-105 :: EF 100/2.0 :: EF 75-300
580EX :: 420EX :: 540EZ + Transistorpack E
$tephen
Joined Aug 2003
May 19, 2004 08:07 |  #9
Martin
Its even quicker if you have CS. Use the Shadow/Highlight command
Image>Ajustments>Shadow/Highlight, then tweak to suit
Stephen
My Personal Galleries (external link)
Don ­ Ellis
Joined Sep 2001
May 19, 2004 08:16 |  #10
I use this feature regularly and didn't even think to try it here (preferring to sharpen my non-existent Extract skills). Thanks for the reminder.
About 10% looked decent to me... remembering that it lightens her hair as well but that seemed to be within reason. And if you don't want lighter hair, you can duplicate the layer, use Shadow, then erase the bits you want original.
Again, thanks.
Don
mvrekum
Joined Jan 2004
May 19, 2004 11:17 |  #11
I don't have CS (yet), so I can not try it, but doesn't affect the whole image?
Martin
MrChevy
Joined Jan 2003
May 19, 2004 11:18 |  #12
Thank you Don, Martin and $tephen. I can't do anything until I get home, there is NO way to look at what you did correctly without being on a profiled/calibrated monitor and this notebook I am on is close but like they say: No cigar as far as looking at colors correctly :)
I will try all of your ways and report back to each of you. Thank you all for helping me learn something!
Ken
Ken Chevy
HKMonkey
Joined May 2004
May 20, 2004 21:28 |  #13
One thing to be careful of when selecting the background is the hair on her head. Since it was a quick retouch, Martin's selection must have gotten her hair that is by her turtleneck. The results are some goofy looking hair around that area. I always find selecting around hair very difficult, and usually I don't do a very good job, but it's something to look out for.
Aaron Presley
"Finally, brothers, whatever is true, whatever is noble, whatever is right, whatever is pure, whatever is lovely, whatever is admirable--if anything is excellent or praiseworthy--think about such things." -Philippians 4:8
timmyquest
Joined Dec 2003
May 20, 2004 22:07 |  #14
WEEE my turn
I think i overdid it...i was trying to go for something but it didnt quiet turn out how i pictured it.
HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by ADVERTISEMENT
Capturing life a fraction of a second at a time
Don ­ Ellis
Joined Sep 2001
May 20, 2004 22:25 |  #15
timmyquest wrote:
WEEE my turn
Then why are you posting it, Timmy? :shock:
Ani looks like a lovely person, but you probably don't want to mess with her... just ask Ken. Even if she's too polite to kick your butt she may not give you dessert, and judging by the look of her desserts (other posts), that would be punishment enough. :)
Don
4,056 views & 0 likes for this thread, 11 members have posted to it.
1266 guests, 121 members online
