Tapeman wrote in post #3267181
My first results are not very good. Small vertical lines and inconsistant color. My crappy HP 5650 produces better 8 1/2" x 11"s. I hope it is just me. Maybe it is too early to make judgements. I'll play around & hopefully figure it out. I have hardly spent any time with the manual.
Any sugestions, besides read the manual?
BTW it's a refurb but looks perfect.
The vertical lines, I presume are following the path of the printhead, right?
If so, it is a dirty print head. You can try some more cleaning cycles or take a pad of papertowel and soak it in windex and place it on the spot where the heads park. Power down the printer and park the head on that for a bit, then do another cleaning. Should be fine.
The problem with any of these printers, and the R1800 is no exception, is that it will use a lot of ink in cleaning. This happens automatically when you turn it on and when you change a cartridge. The carts are little so they run out pretty fast. For that reason, I use a CIS on my printer (which works very well).
J
