Thread started 27 May 2007 (Sunday) 12:03
Lightroom processing
canon ­ shooter
May 27, 2007 12:03 |  #1
I am still learning LR and the way it works. But if I import to LR and process some of the images now and then close LR and come back to finish the rest latter will the adjustments I made be saved in LR? Or do you have to export to save the adjustments?
And I understand none of the changes made in LR effect the RAW image??
Jim
5D Mark III Grip, 40D Grip, Canon 17-40L, Canon 24-105 F4L IS, Canon 70-200 IS II F2.8L, Canon 100-400L, Canon 50 F1.4, Canon 100 F2.8, Canon 580 EX
It's the Glass that Counts!
viatorum777
May 27, 2007 12:06 |  #2
LR saves the adjustments. And yes, the adjustments do not affect RAW files. The adjustments are saved in the LR database.
Canon 30D || 17-40L || 50 1.8 || 85 1.8 || Flickr (external link) || theologiaviatorum (external link)
canon ­ shooter
May 27, 2007 12:09 |  #3
viatorum777 wrote in post #3274940 (external link)
Great so matter how much later I come back to finish the adjustments will still be there?
Thanks, which now brings up another question. Since the adjustments are saved in LR database, I must assume this will take up a lot of hard drive space over a period of time?
If so, should one delete items from the Library once all adjustments are made and saved to hard drive to free up usable space?
Jim
Victoria ­ Bampton
May 27, 2007 12:20 |  #4
Lightroom stores all adjustments in the database, so you'll be pleased to know it won't affect your jpegs either!
The Lightroom database is stored in an SQLite format, and being all text, it should stay a fairly reasonable size indefinitely. I've heard of databases reaching 100,000 images and still being manageable, although it can slow up LR by that stage! The only thing which could get a bit too big is the previews, which you can choose to delete every so often, and it will re-render the ones it needs.
Make sure you back up your database from time to time, as the greatest risk it corruption. You could also use Metadata > XMP > Export Metadata to Sidecar files as a good backup mechanism - this will write all of your changes to xmp sidecar files next to the originals (or writes back to the jpegs if not raw).
Victoria :D
Lightroom Queen website (external link)
Free & Comprehensive Lightroom Books (external link)
Free List of Lightroom Keyboard Shortcuts (external link)
rfreschner
ishka bibble
Joined Jan 2005
Location: Andover, CT...................... Go Red Sox!
May 27, 2007 12:24 |  #5
To add to what Victoria said, if you work on a lot of images in one session you might want to start up LR again right after shutting it down, as it does its backup on startup not on shutdown.
Rick
"We both can't be wrong; I must be right"
Bob Welch
Glenn ­ NK
May 27, 2007 12:34 |  #6
canon shooter wrote in post #3274952 (external link)
1) The "edits" are stored in XMP files. The largest I have is 9 KB, hardly an issue. The only other files I can find are the CR2 (Raw files), the largest of which is about 8,000 KB.
2) I'm not aware of any method of deleting items from the Library, and still having them available. Perhaps someone else can answer this.
I work only in Lightroom, so there are no TIFF, DNG, or PSD files of the same images, which incidentally can be gigantic compared to RAW files.
It seems to me that LR is the most efficient program in terms of storage of images because it doesn't have to convert files to another format - which all other programs must do as far as I know.
EDIT: Just read the comments by Victoria and Rick - very good advice - regular backups, and exiting LR and starting again (I've discovered that trick).
When did voluptuous become voluminous?
rfreschner
ishka bibble
Joined Jan 2005
May 27, 2007 12:48 |  #7
Another way to do it would be to export your settings to DNG files which would allow you to delete the images from your LR library without losing the adjustments. I really haven't played much with it because I can't store full-size previews there yet, but will have the ability in1.1.
Rick
Bob Welch
DavidW
May 27, 2007 13:03 |  #8
Further to Glenn's post, automatic creation of (and synchronisation with) XMP files isn't the default - though I'd recommend it, particularly if you want to share settings with Adobe Camera Raw.
Look on the File Management tab in Preferences - the setting you want is "Automatically write changes into XMP" under Metadata.
David
nwa2
May 27, 2007 13:10 |  #9
The ability of LR to make adjustments without changing the originals is a great feature. In addition you can make multiple changes to the same file store all the changes and still never effect the original.
Canon 6D; 7D; 40D:
There are many tomorrows', but only one today!!
[SIZE=1][COLOR=Black]http://www.Abercrombie​.me.Uk (external link)
http://imagesix.wordpr​ess.com/ (external link)
Victoria ­ Bampton
May 27, 2007 14:01 |  #10
DavidW wrote in post #3275151 (external link)
David
That's a good point, but be aware that it can slow down LR's performance quite dramatically, as it writes the changes back to disc every time you make a change, and writing to XMP is much slower than writing to the database.
If you are concerned about the speed of LR, you may prefer to leave it turned off, but select all of the files and use Metadata > XMP > Write metadata to sidecar files once you've finished making your changes.
Victoria :D
blinktwice
May 27, 2007 22:23 |  #11
Is there anyway to move the adjustments made in one machine to another machine
Lowbyte
May 27, 2007 22:41 |  #12
I do it all the time. When shooting events I create a directory for the event, then copy all the raw files off the cards into it (you can have LR do this for you if you like) When I start LR I have it create a new database in the event directory.
I fly thru my inital rate and reject of all the images on the laptop in LR, then remove the throwaways. If needed I'll export jpgs or create a slideshow.
When I return to the office, I will copy the event directory to my photo workstation. Since I have the LR database and the photos all under one directory everything stays together. When I start LR on the photo workstation I point it at the database I want to work with at that moment.
I hope that made sense :-P
Lowbyte
May 27, 2007 22:46 |  #13
Just as an example this is what it looks like on disk:
 f:\event
Backup <--- Directory created by lightroom
Lightroom Previews.lrdata <--- Directory created by LR
raw <--- Directory where I copied my *.CR2 raw files to
Lightroom Database <--- The LR DB file
Output <--- Directory created by me when I exported images
Then I just copy f:\event to the workstation. In preferences you can tell LR to always ask you which database to use on startup.
blinktwice
May 27, 2007 23:20 |  #14
Thanks you so much, I knew there was a way but I couldn't think of it. Thanx
Lowbyte
May 28, 2007 00:05 |  #15
No problem- glad I could help.
Now I'm just eagerly awaiting the LR 1.1 release that should allow moving objects (pictures/crops/virtur​al copies} between LR databases. :)
2,019 views & 0 likes for this thread, 9 members have posted to it.
2635 guests, 163 members online
