bacchanal wrote in post #3276387
Are you taking pictures of the event or the paintings themselves?
The 50 isn't so great for group shots unless you have room to move. I'm not so sure about the kit lens in indoor light though...people will be moving and you'll want decent shutter speeds. Most libraries that I've been in aren't what I would call bright. Keep in mind that you have to be careful about the shallow dof of the 50 when taking group shots. I'd try the kit lens (meter off of things when you first get there), and if you're not getting decent shutter speeds, go with the 50, just be mindful of your dof.
Thank you for the answer
I will be taking pictures of the event, maybe a few paintings, but only maybe.
I have found a photo of the librarie on the net. It is a horrible picture, but... you can see that the light is ok, there is a huge winodw (behind the two of them), so that helps...
| HTTP response: 404 | MIME changed to 'image/gif' | Byte size: ZERO | PHOTOBUCKET ERROR IMAGE |
I am not happy with the pictures that I get with my kit lens, but I am afraid that 50 would limit me too much.
Should I use the on camera flash, or not?
Canon EOS 400D, 18-55m, 50mm 1.8.
