Thread started 27 May 2007 (Sunday) 23:07
How would YOU process these images?
FrankTheSpank
Joined Nov 2005
May 27, 2007 23:07 |  #1
I know they're not the greatest pictures, took 'em just before the sun went down. I'm still learning my Sigma lens. But I wanted to know what would you have done when post processing these images. I did the best I could, need some tips and tricks to make 'em better.
First one was at ISO 200, last two at ISO 1600, the flower I used Noise Ninja, I'm still learning that filter... most of the time it seems like it adds more noise and reduces it, but I got some decent results from the flower.
HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by TINYPIC
Thanks for any help, tips and advice.
Canon 1D Mark II N | Canon 24-70mm f/2.8L | Canon 50mm f/1.4 | Sigma 70-200mm f/2.8 II EX DG APO HSM Macro | Canon 430EX | Lightsphere II
jj1987
May 27, 2007 23:30 |  #2
I would sharpen them after running NN. Personally (and this is going to be your artistic decision) I prefer a sharp image even if it has grain to it, rather than eliminating noise with noise ninja all together and sacrificing some sharpness.
I usually run NN and then sharpen after that. It brings back some noise, but I try to find a happy medium.
FrankTheSpank
Joined Nov 2005
May 27, 2007 23:45 |  #3
Ah, same here. I'm still learning sharpening and noise redducing and trying to find a happy med. Other than that... how is contrast, white balance etc.?
jj1987
May 27, 2007 23:54 |  #4
I think that 1 and 2 could use more contrast (might actually help with the sharpness believe it or not!). Three IMO could be presented a little cooler (more towards the blue side) to make more of a true green and rich pink.
If you make it in your profile where we can edit your images, we could show you. Also, next time downsize the images a bit more. For people like me who have 12in laptops and are traveling, we can't see the whole image. The forum guidelines also restrict size, but moderators are understanding to new members about this type of thing.
If you haven't figured out resizing yet, in photoshop go to "Image-> Image size".
D.E.P
May 28, 2007 00:06 |  #5
what i did was reducing noise & sharpening the image, brightnest & contrast etc...
took me only 5mins for each image.
jj1987
May 28, 2007 00:30 |  #6
D.E.P wrote in post #3277812 (external link)
Note- the original poster never gave permission for his images to be edited.
If you look to the left, you'll see how mine says image editing okay. If a user doesn't post that, it's against forum rules to edit their images.
You're new here, and it's different than many forums, so accept this as a helpful heads up with no hard feelings meant. :D
FrankTheSpank
Joined Nov 2005
May 28, 2007 01:24 |  #7
jj1987 wrote in post #3277925 (external link)
Oh it's fine, in fact I am happy he took the time to show me how it's done :D
I'm gonna edit my profile now.
FrankTheSpank
Joined Nov 2005
May 28, 2007 01:35 |  #8
Awesome! They look a lot better I think.
Did you use Noise Ninja to reduce noise or the built in tool in Photoshop? Also when sharpening which option did you use? I see a bunch of options to sharpen a pic, smart sharpen, unsharp mask etc.
For the contrast and brightness, did you simply use the Brightness/Contrast sliders in Photoshop:
Or something else?
I shoot in RAW and I heard about tweaking the contrast with that "curve" in the RAW tools screen. I've fooled around with that and didn't get that great results...
Also sorry everyone for the large photos, I made 'em big so you all could see the detail and I figured since this is a photo forum you all have giant LCD's, LOL
I'll knock 'em down to 800x600 next time.
D.E.P
May 28, 2007 02:32 |  #9
Hi Frank.
in CS2, yes using Slider for Brightnest & Contrast - 1st
very gently control slider Color -> Red, Green & Blue - 2nd ( to get color u want )
i use Neat Image for noise reduction - 3rd ( shouldn't make any different to Noise Ninja )
last Filter -> Sharpen -> Unsharp Mask.
just follow this steps and you will have very same results. ;)
PJEP
May 28, 2007 07:29 |  #10
Tried to give some depth with PopGlow action I use
PJEP
May 28, 2007 07:44 |  #11
Split-Tone BW
Sometime I like the flowers in black and white so for this I make mono and then I split-tone action from http://www.1clickactio​ns.com (external link)
poloman
May 28, 2007 11:09 |  #12
The first photo suffers from motion blur. You may have missed focus as well (note leaves and more focused spot on cat's back) Tough to fix this.
PJEP wrote in post #3278946 (external link)
thumbnail
Hosted photo: posted by PJEP in
./showthread.php?p=327​8946&i=i222424912
forum: RAW, Post Processing & Printing
PJEP There are sharpening artifacts in this rendition.
A few tips that might help in low light.
Use a tripod
Make sure your speed will compensate for motion in your subject.
Be sure not to underexpose at high ISO.
Fill flash might help freeze the motion for you. (warning...cats don't like it)
Happy shooting!
"All those who believe in psychokinesis, raise my right hand!" Steven Wright
howzitboy
May 29, 2007 14:44 |  #13
heres my version of the first picture:
i adjusted color balance, light/darkness. then i seperated the cat and desaturated the background and gaussian blurred it a touch. then i put the cat back in and using the smudge tool, smudges his fur to look like fur again. I left the glow on the right because it looked like a highlight. Then added one sharpen.
flattened image, cut out it into a vertical and pasted in new image.
came out okay i think..
http://onehourwedding.​blogspot.com/ (external link)
2,157 views & 0 likes for this thread, 6 members have posted to it.
2634 guests, 163 members online
