Pollyanna1 wrote in post #3279628
Thanks for your advice SaSi. Would this only work with the Canon 2XTC? I thought all AF would be lost with this lens with anything above 1.4X, could you explain?
You are right to think that a 2xTC will give you a max apperture of f/8, thus no AF.
But the camera will only register the TC closest to the lens. Your 1.4xTC attached to the lens will make it a f/5.6 lens, which can AF.
Attaching another 1.4xTC or 2xTC to the back will cause you to lose 1 or 2 f-stops, but the camera will still view the whole thing as a f/5.6 lens - only darker.
In theory, you can stack a 2xTC and a 1.4xTC and still have AF, provided there is enough light for the AF sensors to make out contrast changes.
I have been able to use a non-registering 2xTC with my 500/4 and still use AF. But now it is summer (well almost) and pretty sunny (most of the time). Shooting with this combination when the sun is up, gives me fast and accurate AF.
Even so, I am wondering if the best thing for you is a new 2xTC or another 1.4xTC. The 2xTC will cause a significant drop in IQ when used stacked with the Kenko. Perhaps a Canon 1.4xTC stacked with the Kenko is a better option, however giving you only 400mm reach in total.
Additionally, the 1.4xTC needs to be the first to go on the lens. I am not sure if the Kenko TC has a slot in the back for the front element of the Canon TCs to fit. If not, then you will need to attach the Canon TC on the lens, so you must get a 1.4xTC.
I hope I haven't confused you (much).
