Thread started 28 May 2007 (Monday) 12:20
100mm Macro USM and Hood
bufferbure1
May 28, 2007 12:20 |  #1
Does anyone have problems with flare with this lens? My copy seems to flare quite easily when shooting landscape. And would you recommend buying a third party hood? The Canon ET-67 hood costs 3 times as much as the third-party hood. Thanks.
"I collect pictures, not gears..."
Lenscode:1635.1785.50f​18.100Macro.70200F4IS.​580EX.30D.5D2
Lester ­ Wareham
Moderator
Gallery: 3035 photos
Best ofs: 5
May 28, 2007 12:27 |  #2
bufferbure1 wrote in post #3280263 (external link)
My one is very well controlled for flare but you should always use a hood for all lenses. Get the specified Canon hood, it is large and well designed.
Macrophotography by LordV
bufferbure1
Jun 05, 2007 20:12 |  #3
Anyone knows if this replacement hood is the same size as the Canon brand?
http://cgi.ebay.com …ViewItem#ebayph​otohosting (external link)
Lester ­ Wareham
Moderator
Best ofs: 5
Jun 06, 2007 03:26 |  #4
Who knows, considering how much one pays for camera and lenses why mess around, just get the Canon hood.
devil350
Jun 06, 2007 06:14 |  #5
Yes, it's true, get the original one, you'll have what exactly fit the lens needs...
Genuine is often the best way to avoid problem.
Of course this hood is a bit expensive, but very well bild, the inside is covered with special material that will avoid sun bean reflection...
So, go for the ET-67. You have a good lens, so get the best gear for it ;-)a
Ciao,
Laurent.
MY Gear List | My Gallery (external link)
Prydain
Jun 06, 2007 06:55 |  #6
Buy the Ebay hood. It fits fine and works well. This is a case where you don't need the name brand.
Mel
Couple of bodies, couple more lenses, some stuff to set them on and carry them in.
Prydain
Jun 06, 2007 08:02 |  #7
It appears that I am the only one that has one of the Ebay hoods that has commented so far. The Ebay hood is obviously a copy of the ET-67. I see no difference in 'build quality' between the two Ebay hoods I purchased at a third the cost of Canon and the hoods that came with my two L lenses and the DO. Both have nice snug fits to the lenses in both normal and inverted modes. It takes a little longer to get them, but they are sent registered mail so they don't get lost. I believe they will give good service for a long time. The other Ebay hood I bought was for the 50f1.4. Again, simply good value, IMHO.
Mel
Lester ­ Wareham
Moderator
Best ofs: 5
Jun 06, 2007 12:11 |  #8
Prydain wrote in post #3329822 (external link)
Mel can you confirm for the OP if the inside of the hood is flocked.
Sathi
Jun 06, 2007 17:38 |  #9
I bought the ebay 100mm lens hood. It seems from the outside to have the excact same dimensions as the real thing and feels reasonably solid and well made. The inside of the hood is smooth flat black plastic. Slightly different from the exterior finish. I bought another ebay hood for my 10-22 and the inside has this felt like finish. My tamron lens hood has grooves on the inside. I am not sure if it makes makes much of a difference but I couldn't see spending 3X more for a piece of plastic. Honestly I would be very surprised if a side by side performance comparison would show any differences.
20d / Tamron 28-75 2.8 / Canon 10-22 / Canon 100mm macro
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Jun 06, 2007 17:46 |  #10
If I remember correctly the front element of the lens is very exposed and at the end of the lens barrel. Many other macros have a bit of the lens barrel that extends past the front element. Because of this design, it may be more prone to flare.
I do agree that a hood is recommended, also if you have a UV filter, I'd take that off as well as UV filters may increase flare.
Good luck.
Gallery: http://tomyi.smugmug.c​om/ (external link)
DerekI
Jun 06, 2007 18:49 |  #11
Do you need a food for this lens?
I am getting it as I ditch my 18-200OS (a very ****ty lens).
But I dont think it'll need a hood ...............
I think the 60 macro is the best macro lens for product phototos and street photos but the 100 is the best for many other things like insects and head shots...
But when will you need a hood on the lens?
Canon EOS40D(2).
EF-S17-55IS,EF70-300DOISUSM,EF-S60f2.8USM, EF-S55-250IS,EF-85f1.8USM.
Nikon D300, AFS12-24, AF-S16-85VR,AF-S18-200VR, AF-S70-300VR,AF35f2D.
http://www.flickr.com/​photos/izumiflowers/ (external link)
bufferbure1
Jun 06, 2007 19:49 |  #12
Sathi wrote in post #3332754 (external link)
Sathi, any pic of the 100mm hood to show us? Which ebay dealer? Thanks.
Prydain
Jun 06, 2007 20:11 |  #13
Mine also does not have a flocked interior. However the Ebay hood I bought for the 50 1.4 is flocked on the inside. They came from different HK vendors, and I do remember the ad for the 50 1.4 mentioning the flocking. These vendors are normally pretty responsive to questions. By all means send them a question using Ebay's system and ask before you buy if it has fuzz on the inside surface. I'm sure you'll know one way or the other before you buy.
Mel
Lester ­ Wareham
Moderator
Best ofs: 5
Jun 07, 2007 06:06 |  #14
That is not ideal better than nothing but the inside should be flocked to be fully effective.
Lester ­ Wareham
Moderator
Best ofs: 5
Jun 07, 2007 06:09 |  #15
DerekI wrote in post #3333058 (external link)
Yes the front element is not recessed.
Anytime you are not shooting flash.
2,575 views & 0 likes for this thread, 10 members have posted to it.
961 guests, 138 members online
