Thread started 17 May 2004 (Monday) 19:39
Upcoming photo shoot
NILOLIGIST
Joined Jan 2003
May 17, 2004 19:39 |  #1
I have been asked to photograph a very small and informal wedding. The groom is much darker than the bride (like night and day), I am thinking I should expose for him? If I expose for her he will be too dark right ? Or do I have that backwards?
Any help, suggestions or shrugs are NEEDED!!
NiL,
Canon 1D Mark II, 24-70 f/2.8L, 17-40 f/4L, 70-200 f/2.8L. 580EX, 4 - Alien Bees, Gitzo Tripod, Bogen Monopod.
My websites
http:// (external link)www.frederiqueporter.c​om (external link)http://www.musecube.co​m/photosbyrica (external link)http://www.pbase.com/n​iloligist (external link)
robertwgross
Joined Nov 2002
May 17, 2004 20:23 |  #2
The normal wedding problem involves a groom wearing a black tuxedo and a bride wearing a white gown. In general, the clothing takes up more of the frame that just face color. That is enough dynamic range to complicate getting a correct exposure.
To look at the problem another way, if you are trying to shoot white snow with zero exposure compensation, it will end up looking kind of a murky gray. If you use +1 or +2 exposure compensation, it looks like normal snow. A piece of black cloth can be shot with -1 or -2 exposure compensation to look right.
---Bob Gross---
Vegas ­ Poboy
Joined Aug 2003
May 17, 2004 20:23 |  #3
you said it correctly, use flash & check the histogram on some test shots. You may want to set the flash on manual so you won't overexpose her but yet get enough light to get detail in him.
$$$ in Canon Gear & Lighting Equipment
G3
Joined Jan 2004
May 17, 2004 20:40 |  #4
This is going to depend on if you are shooting outdoors or indoors. If you are shooting outdoors use fill flash and meter for the subject off a gray card and use that for the "correct" exposure, then bracket one stop in either direction.
If you are shooting indoors with ETTL flash you will have to take into account what color dominates the shot...for instance, if you are shooting the bride and she is wearing a white wedding gown, then the gown will be the biggest factor in the shot. The meter will try to average the shot with all that white in it. It may end up exposing the gown correctly and everything else will be underexposed. You can tell by the histogram how it did. If the data in the histogram is shoved all the way to the left and there's a gap on the right side, then open up a stop and shoot another one. As long as all of the data in actually in the histogram and not jammed up against the right or left side, it can easily be corrected in Photoshop.
One other tip. Get your flash off the camera. Use a Stroboframe or some other flash bracket. Try to bounce the flash off the ceiling if you have a fairly low, white ceiling to work with.
NILOLIGIST
Joined Jan 2003
May 18, 2004 21:55 |  #5
Thank you all.
NiL,
My websites
scottbergerphoto
Joined Jun 2003
May 19, 2004 06:38 |  #6
Good luck Nil!
Scott
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography (external link)
mjordan
Joined Apr 2002
May 19, 2004 19:52 |  #7
With dark skinned people, as with dark tuxes, black dogs, or other dark material, it's not how much light you blast them with from the front that brings out the detail. It's how you light them from the side. Side like is used on dark people to create the specular highlights that lighter skin reflects with frontal light. So if you can, meter normally (or maybe a 1/2 to 3/4th over) and skim some light across from the side. Either reflected light, a off camera flash or side sunlight. This is the same for a white wedding dress. If you skim light across the front of it, you will bring detail out that you won't see with just frontal lighting.
Mike
Hillsboro, OR
Canon 1DMKII and lots of "L"
http://www.sitnprettyp​hoto.com (external link)
NILOLIGIST
Joined Jan 2003
May 19, 2004 20:42 |  #8
I will give it all a try. If they don't come out good, don't expect to see them. LMAO
NiL,
My websites
G3
Joined Jan 2004
May 19, 2004 20:44 |  #9
NiL,
But that's the ones you really need to post, so you can get some ideas of how to correct it next time.
NILOLIGIST
Joined Jan 2003
May 19, 2004 21:18 |  #10
hmmmmmmmmmm
NiL,
My websites
defordphoto
MKIII Aficionado
Joined Oct 2002
May 19, 2004 21:31 |  #11
Well, the nice thing is you now have the wide(r) dynamic range of the MKII so post processing should be easier than say, with a 10D.
defordphoto | Celebrating the art of photography®
SD500, 10D, 20D, 30D, 5D, 1DMKII, 1DMKIII
www.ussbaracing.com (external link) | www.rfmsports.com (external link) | www.nwfjcc.com (external link)
An austere and pleasant poetry of the real. Ansel Adams
NILOLIGIST
Joined Jan 2003
May 19, 2004 23:45 |  #12
That is for sure. And...Another excuse to buy a new lens. My next few purchases are...
70-200 L 2.8
85 1.2
135 2.0
That should hold me. Don't know the order yet. I am booked to shoot a dance festival next month and will be getting one for that. Oh, the worries I have. LOL
NiL,
My websites
msvadi
Joined Jul 2003
May 20, 2004 07:23 |  #13
NiL,
NO!!! it's always the bride ;)
Dans_D60
Joined Apr 2002
May 21, 2004 06:22 |  #14
Yes…The primary objective is images of the bride and her party.
Also, direct midday sunlight can be challenging. Here is a proof sheet web site for a wedding I shoot last weekend in California. 90F and the wedding were scheduled between 11:00AM – 2:00PM. The worst time to shoot. Can’t change the environment and one just needs to do the best they can. Even a fill flash has difficulty in this situation.
http://www.pettusphoto​.com/perkins (external link)
Dan (external link)
Dan Pettus Photography (external link)
BLOG (external link)
FB (external link)
psk4363
Joined Jun 2003
May 21, 2004 06:42 |  #15
Hi NiL,
Why not invest in a good quality light meter? Then you can take an incident light reading from the position of your subjects. Transfer the readings for Tv and Av to the camera in manual mode and fire away.
Whites will come out white, blacks will be black, etc with no exposure adjustment necessary as you would have to if you relied on the camera's (reflective) meter reading.
Providing the light source remains constant you can leave the settings intact - if it changes take another reading!
Cheers,
Barry
A little G9 :D
2,780 views & 0 likes for this thread, 11 members have posted to it.
2162 guests, 124 members online
