sonshine_rae wrote in post #3289413
Actually it looks okay.. if I preview the RAW image in Digicam, but whether I try to do the conversion in Digicam or The Gimp/ UFRAW the image that comes up for conversion (the file you 'edit' to be converted') looks way off.... and if you convert that file as is.. it'll convert to a poor looking jpg.. having lost a lot of saturation.. color etc.
Okay that makes some more sense then. I haven't used Digicam so I can't speak for it but UFRAW doesn't get the camera curve as a starting point. So unless you have downloaded some curves it will appear a little odd. You can try downloading some curves (there are a few links on this page http://ufraw.sourceforge.net/Guide.html
For me, I tend to just grab a point on the top right corner and drag it left and down a bit. I may also adjust the exposure a little as well.
I've attached a sample of the curves I use -- just rename them from .txt files to .curve files.
If your colours are looking a little subdued then you can try the "use colour matrix" on the colour tab (if that option is available to you). It may be a little over the top though. Also, if you had say a +2 on saturation for your camera settings then this is what you will see in the preview image as they generally use the embedded JPEG. As a result you need to boost the saturation in UFRAW to make it look the same.
You can also set the input profile to one you have copied off of your Canon CDs (you can find information on this at http://www.maashoek.nl/color_profiles.html
and http://staffwww.itn.liu.se …ufraw_with_canonSLR.xhtml
). Personally, I leave the input/output profiles as sRGB.
sonshine_rae wrote in post #3291657
Well ...... hmm I seem to be able to just about 'fix' them using the Exposure compensation now. I've noticed it seems to 'remember' between files what the last file's exposure adjustment was.. and I'm beginning to think that's the main problem. There is an 'assumption' in the UFRAW program that the next file will need the same adjustments... and hence things tend to look poorly since they don't.
You're right. Generally the assumption works out okay. On the UFRAW site I think the have a page that deals somewhat with this and how to work around it.
But I guess back to the original issue..... is there anyway to see the file persay 'untouched' by adjustments within UFRAW? Sometimes I'd like to use it exactly as it was taken in the RAW format.. without making huge adjustments..
Within UFRAW, no. I think the 'untouched' image you're referring to is the embedded JPEG. This has already been converted from RAW to JPEG by the camera's built-in facilities. Unfortunately UFRAW, unlike Canon's DPP, is not privy to the algorithms used to convert RAW files to JPEG in camera.
e-k
