Thread started 31 May 2007 (Thursday) 21:36
copy layers in cs2?
Crashoran
Joined Nov 2005
May 31, 2007 21:36 |  #1
Is there a way to copy the layers from one file in CS2 and use them on another file? Layers such as color correction, etc.
vash
May 31, 2007 21:50 |  #2
In the layers applet, right click on the source layer -> click on Duplicate Layer... Next, in the dialog box, select either the file you are working on, for a copy of the layer, or select the target file (file needs to be already open), or select New to create a new file. Change the name of the layer if you want, hit OK. Done.
peppies
Jun 01, 2007 00:11 |  #3
As far as I know there is no way of copying adjustment layers between files. But you can save each layer adjustment settings and then load it for any new file. Hope this is what you want.
René ­ Damkot
Jun 01, 2007 06:26 |  #4
Just drag and drop works fine. (from the layers palette of the old onto the canvas of the new file)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Swift
Jun 01, 2007 17:51 |  #5
Yep, drag the adjustment layer to the other opened file in Photoshop and it should work flawlessly the way you wanted it to.
Canon 550D | Canon 70-200mm f/4L USM | Canon 17-55mm f/2.8 IS USM | Canon Speedlight 430EX | Raynox DCR-250 Macro
S.Horton
Jun 01, 2007 19:04 |  #6
Are you thinking that you'd like to do this in a batch as well?
Sam - TF Says Ishmael
:cool:
925 views & 0 likes for this thread, 6 members have posted to it.
copy layers in cs2?
2694 guests, 171 members online
