I noticed my 10D has a very slight back focus, so I did The Ruler Test. I made one shot with auto-focus, using the center focus point, and one with manual focus. For both shots I focused on the "20" on the ruler (the number was exactly in the center AF square). This is what I got:
![]() | HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
Clearly, with AF, the "19" is more in focus than the "20", while with manual focus, I was able to get the focus exactly on the "20".
What can I do about this? Can Canon re-calibrate the focus to make it exactly accurate? Did you have this problem and did you bring it to Canon, and did they repair it well?
Just wondering. This thread led me to the Adkins test. I set it up and Like Jasper, my 10D is fine. Not only that I tested all me lens. 100-400, ( at different lengths) 100mm macro and 24-85. None were more than 1-2 division off center!!! Now I have a easy test in case I get paranoid again
