Thread started 02 Jun 2007 (Saturday) 09:14
Who is good with math?
flaclick
Jun 02, 2007 09:14 |  #1
Hi
Hope someone can explain this to me....
When I bring one of my cropped/edited photos into PS, the image size is 19.25 MB (for example). I need to resize it for a contest, so I change the resolution to 300 and lower the pixel dimensions, so the new file size is now 4.81MB.
Now, when I view that same photo in Bridge in the Metadata, it says the file size is 263KB?
Why?
Thanks :rolleyes:
Ruth
Ruth
Canon 5D MII :) ~ Canon EF 70-200mm f/4L USM ~ Canon EF 100mm f/2.8 Macro ~ Tokina 12-24mm f/4 AF DX ~ Canon 100-400mm f/4.5-5.6L IS USM ~
Photoshop CS3
madddman
Jun 02, 2007 11:33 |  #2
Hi Ruth,
I'm guessing that you saved your file as a .jpg file. This file type uses a compression algorithm to make the file smaller when it is closed. When you look at a .jpg file when it is opened, it will show as it's actual size, when you look at the file when it is closed, in bridge, it shows the file size as compressed by the .jpg algorithm . The compressed file size will vary depending upon the quality setting that you use when you save as a .jpg. The higher quality setting you choose, the larger the .jpg file will be when closed. Using a lower quality setting makes the file smaller when closed, but can degrade the image quality.
I hope this helps,
Ed
Ed
Fuji X-T2, X-T1, X-Pro 1, Lots of Fuji Lenses
flaclick
Jun 02, 2007 13:41 as a reply to  @ madddman's post |  #3
Thank you Ed, it makes sense. Thanks for taking the time to answer my question.
Ruth
Ruth
Photoshop CS3
899 views & 0 likes for this thread, 2 members have posted to it.
2783 guests, 167 members online
