Thread started 02 Jun 2007 (Saturday) 18:10
Huey's Not Stayin' Put
Mark_48
Jun 02, 2007 18:10 |  #1
Anyone have any tricks to get the Huey to stay put on the monitor during calibration? The suction cups just don't seem to hold very well, even after swabbing the screen with a wipe and I'm a little reluctant to press too hard on my LCD screen to try and get them to stick better. When it lets loose the cable tends to turn it. I've thought about attaching some wire legs to it and just let it rest against the screen which tilts back a bit.
Megapixels and high ISO are a digital photographers heroin. Once you have a little, you just want more and more. It doesn't stop until your bank account is run dry.
cdifoto
Don't get pissy with me
Jun 02, 2007 18:15 |  #2
Lick the suction cups.
lurkalot
Jun 02, 2007 18:41 |  #3
Hold it on. It only takes a minute. ;)
Mick :) Canon 30D, Sigma 50-500 EX DG HSM. Tamron SP 90mm F/2.8 Di Macro.
My Website Camera Craniums (external link)
R_Metzel
fish stick man!
Jun 02, 2007 18:53 |  #4
lurkalot wrote in post #3309307 (external link)
Thats what I do. I just pinch on the sides at the top and hold it there.
-Rob-
www.blacktiefoto.com (external link)
gear
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Jun 02, 2007 19:11 |  #5
I cleaned the dust off the suction cups after cleaning the LCD and that seemed to work for me.
Gallery: http://tomyi.smugmug.c​om/ (external link)
LBaldwin
Jun 02, 2007 19:16 |  #6
cdifoto wrote in post #3309219 (external link)
Hey wait a minute you mean I been doing wrong the whole time? Licking the monitor is NOT reccomemnded. I do get a nice tingly sensation from time to time though. :oops:
Really, clean the screen prior to testing...
Les:o
Les Baldwin
http://www.fotosfx.com (external link)
Mark_48
Jun 02, 2007 19:18 |  #7
R_Metzel wrote in post #3309343 (external link)
Does it take any ambient reading while on the monitor? I was thinking if I held it in place it may not take a true ambient read due to shading by my hand.
I suppose that would help and swab the screen after. Yuk, spittle on the screen :p
cdifoto
Jun 02, 2007 19:20 |  #8
My spittle is like pure spring water. No harm done.
davidcrebelxt
Jun 02, 2007 19:48 |  #9
if you can tilt the monitor, tilt it back while calibrating, and let gravity hold it on.
David C.
Equipment: Canon Dig. Rebel XT; 18-55mm EF-S; 28-105mm EF; 50mm 1.8 EF
Sigma ef-500 DG ST, Elements, Gimp, Lightroom
http://www.flickr.com/​photos/dcrebelxt (external link)
TeeJay
Joined Jun 2005
Jun 03, 2007 01:36 |  #10
The manufacturers of Huey recommend to NOT stick the device to an LCD screen - as if it does stick tight you could easily damage your monitor getting it off.
Simply hold it in place, the process only takes a minute or so.
TJ
1DsMkIII | 1DMkIIN | 70-200 f/2.8L IS | 24-70 f/2.8L | 24-105 f/4L IS | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 430EXII | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea :confused:
tzalman
Fatal attraction.
Jun 03, 2007 04:55 |  #11
Mark_48 wrote in post #3309424 (external link)
No, it measures the room light first, before instructing you to put it on the screen. Besides, the forward looking sensors are in the middle so you can hold it at top and/or bottom without blocking them.
Elie / אלי
Mark_48
Jun 03, 2007 07:10 as a reply to  @ tzalman's post |  #12
That settles it. I'll just hold my Huey and not lick it.;)
1,374 views & 0 likes for this thread, 9 members have posted to it.
2783 guests, 167 members online
