Thread started 02 Jun 2007 (Saturday) 19:31
what does this error msg mean?
flaclick
Jun 02, 2007 19:31 |  #1
Hi Everyone
I just finished calibrating my monitor for the first time, using Spyder2 Express. Everything went fine, it even said at the end that my monitor was calibrated. But right after the last click this message popped up and I have no idea what it's talking about...
"Sorry, no calibration data was found in the profile HP f1905 for display Hp f1905 Flat Panel Monitor. Please select a different profile using Profile Choose (1168)"...
Is there something I need to do? Help!
Ruth:(
Ruth
Canon 5D MII :) ~ Canon EF 70-200mm f/4L USM ~ Canon EF 100mm f/2.8 Macro ~ Tokina 12-24mm f/4 AF DX ~ Canon 100-400mm f/4.5-5.6L IS USM ~
Photoshop CS3
davidcrebelxt
Jun 02, 2007 19:44 |  #2
Windows, right?
right click on your desktop, select properties, settings, click the advanced button, choose color management, and select the spyder2 profile.
David C.
Equipment: Canon Dig. Rebel XT; 18-55mm EF-S; 28-105mm EF; 50mm 1.8 EF
Sigma ef-500 DG ST, Elements, Gimp, Lightroom
http://www.flickr.com/​photos/dcrebelxt (external link)
davidcrebelxt
Jun 02, 2007 19:46 |  #3
oh, then either restart, or go to start menu, programs, startup; then select colorvision startup
David C.
flaclick
Jun 02, 2007 19:49 as a reply to  @ davidcrebelxt's post |  #4
Will try it now. Yes, Windows. :)
Ruth
Photoshop CS3
flaclick
Jun 02, 2007 20:05 as a reply to  @ flaclick's post |  #5
davidcrebelxt
I went thru the steps you suggested. In the Color Management tab, Spyder2Express was already highlighted. I just clicked ok then restarted my pc. Is there anything else I need to do? Is this message mostly due to it being the first time I calibrated? I appreciate your assistance.
Ruth
Ruth
Photoshop CS3
davidcrebelxt
Jun 02, 2007 20:09 |  #6
from the colorvision FAQ page they say that it is a common problem for it not to automatically select it in the colormanagement tab for windows, and that affects all calibrators. That's about as much as I know.
Is it working after you restarted, or are you getting the same message?
David C.
flaclick
Jun 02, 2007 20:14 as a reply to  @ davidcrebelxt's post |  #7
It booted up normally, I saw the colorvision logo screen flash by at startup. No message. It only popped up on the last step of my going thru the calibration process. It's in the color management area now. After all those steps, I printed a picture after the calibration. Compared it to the same pic I printed BEFORE the calibration....looks the same to me. Anyway, I appreciate your help. Thanks.
Ruth:eek:
Ruth
Photoshop CS3
davidcrebelxt
Jun 02, 2007 20:37 |  #8
If no settings changed, the picture SHOULD print out the same I believe. The image on the monitor, however could look different than it did before...
often, just as the colorvision message pops up, you may see the screen change colors slightly as it is applied.... or recalibrate, and at the end you have the option to switch back and forth between how the image looked before and after calibration.
David C.
flaclick
Jun 03, 2007 09:10 as a reply to  @ davidcrebelxt's post |  #9
One more question...
I notice that Colorvision is now in my StartUp although there is no icon in the task bar. I try and keep only what I need in startup. Can I disable it or will that effect the calibration?
Thanks again,
Ruth
Ruth
Photoshop CS3
DavidW
Jun 03, 2007 09:45 |  #10
You need to leave that program there. I don't use a Colorvision calibrator, but you need something to load the correction table from the profile into your video card's lookup table. That's what that program will do - load the LUT when you log on to Windows, then quits.
David
flaclick
Jun 03, 2007 10:06 as a reply to  @ DavidW's post |  #11
Ok will leave it there.
Many thanks to both David's. It's so great when people are helpful towards each other :D
Ruth
Ruth
Photoshop CS3
1,466 views & 0 likes for this thread, 3 members have posted to it.
2783 guests, 167 members online
