Thread started 21 May 2004 (Friday) 07:10
Total newby
KartGirlsMom
Joined May 2004
May 21, 2004 07:10 |  #1
I'm somewhat familiar with EOS cameras, as I have two film cameras, a Rebel and an Elan 7. I have a 17-35 wide angle lens, a 35-70(about that anyway) f4.5-6 zoom and a 70-200 f2.8 zoom plus various filters, tripods, and flashes. I have PhotoShop 7 and am fairly familiar with it.
And on the advice of this board, I am looking at a D10. I know nothing about digital. What besides the camera body do I need? I will mostly be shooting motorsports, gymnastics and volleyball. I am on a fairly limited budget, but I don't see the point in spending any money if I'm not going to get something that will do a good job for my applications. What are good publications for someone who really absolutly nothing about digital photography? Is it better to buy, as I have in the past from a local camera shop, or will I get a better deal with an online supplier? What about Ebay? Thanks so much.
30D|50mm 1.8 | 85mm 1.8 | 70-200 2.8 IS |
JAB1
Joined Apr 2003
May 21, 2004 07:43 |  #2
I would not recommend spending your money on a 10D....too much camera for right now....I would recommend the Rebel instead...still alot of camera...most of the same controls as the 10D...just not all the unnecessary bells and whistles for a newby....
There are alot of good publications for new digital photographers out there...do an internet search or go to Amazon.com and search...
You can get better prices on the Web but not as good of service as you can from your local camera store...
I advise you to shop around.....
Hope this helps....
Scottes
Trigger Man - POTN Retired
Joined Nov 2003
May 21, 2004 07:57 |  #3
I agree with JAB1 based on your description of what you're going to be shooting. I don't think you'll miss the features of the 10D that aren't supported by the DRebel. (Hmmm, does the DRebel support 2nd-curtain flash anyone? That might be nice for you if you use it now.)
You will also need CompactFlash Cards, preferably2 512MBs IMHO, and a spare battery would also be nice.
For suppliers, www.bhphotovideo.com (external link) is generally regarded as the best around here. Not the best prices maybe, but certainly better than a local camera store and they're reliable.
Two publications: Digital Photo Pro and Photoshop User. I don't have much regard for any of the others.
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info (external link)
Follower of Fidget - Joined the cult of HAMSTTR©
IndyJeff
Joined Oct 2003
May 21, 2004 08:04 |  #4
KartGirlsMom, a RebelD would be a step backwards for you, based upon what you are shooting now. The buffer on the Rebel is half that of the 10D and action shots need more than a buffer of 4. Here is a good side by side review of both models.....Rebel vs 10D (external link)
One guy at the track recently told me the Rebel is worthless for motorsorts with it's buffer. Fortunately he was borrowing it and didn't buy one.
Another alternative would be a D60 which is going to be used but will also be less expensive than a 10D.
At any rate, the D60 or the 10D will deliver for you, less FPS than what you are used to but, not difficult to operate at all.
On shooting sports...If you see it happen then you didn't get it.
defordphoto
MKIII Aficionado
Joined Oct 2002
May 21, 2004 08:07 |  #5
Absolutely a 10D. You would not be happy with the Drebel at all. Keep a lookout because many people are selling their 10D's and upgrading to the 1D Mark II. You should be able to find some good deals out there.
defordphoto | Celebrating the art of photography®
SD500, 10D, 20D, 30D, 5D, 1DMKII, 1DMKIII
www.ussbaracing.com (external link) | www.rfmsports.com (external link) | www.nwfjcc.com (external link)
An austere and pleasant poetry of the real. Ansel Adams
blackviolet
Joined Apr 2004
Location: sydney, au (now in singapore for a few years)
May 21, 2004 08:22 |  #6
Scottes wrote:
...(Hmmm, does the DRebel support 2nd-curtain flash anyone? That might be nice for you if you use it now.)...
fwiw: no, the 300d/drebel does not itself support 2nd curtain - even with the russian firmware. however, you can set this within most decent external flash units themselves if it's a requirement.
my $.02: if you are shooting a lot of sports, the buffer may be a bit small for you. i have both the 10d and the 300d (as a backup or for the wife). on the 300d using a fast card (like an ultra ii, etc.), you can burst 4 shots @ ~2 1/2 fps and then continue to shoot every 1 1/2 to 2 seconds, once you get the timing right. on the 10d, i've found that you can burst 9 shots at around 3+ fps and then continue to shoot every 2 seconds or so (using raw - it's a bit quicker if you are shooting jpg). i once missed my youngest son scoring a try (rugby's equivalent of a touchdown) on the 300d as i was bursting through his run. fortunately he scores a lot, so i don't feel that bad...
either way you go, you will definitely be happy!!
oblio
1dmkiii - 5dmkii -Leica M8/M6 - Mamiya 645AFDiii/zd
ModelMayhem (external link) | my (external link)flick (external link)r gallery (external link)
Belmondo
Joined Jul 2003
May 21, 2004 08:28 |  #7
Mom:
The answer to your entire question could be the basis for an entire book, but I can speak to a couple of points.
1. It sounds like you have good coverage in focal range---17mm to 200. Don't forget that the 10D has a sensor smaller than a standard 35mm frame, so you will have a 1.6X magnification 'effect' and and equivalent focal range of 21mm to 320mm. Not bad.
2. The biggest thing you will have to learn is how to handle and process files---work flow. If you've already been scanning film and processing it in PhotoShop, you're already well ahead of a lot of us who came into this thing completely 'cold'.
3. The 10D is very adequate for what you plan to shoot (sports--indoors mainly). Your f/2.8 lens will be very useful for that purpose, and because it is possible to push ISO speeds up quite a bit on the 10D, you should probably be able to shoot with available light. You will probably have to correct for white balance depending on what lights are being used in each particular venue. Flash usually won't be of much help at the normal distances you can expect to be shooting. (and it's often discouraged anyway).
4. If you shoot JPEG (compressed) files, you'll be able to get roughly 80 high resolution shots on a 256-meg Compact Flash (CF) card . You can judge your own needs for how much storage you're likely to need. A lot of us shoot RAW files (uncompressed) and use up storage roughly twice as fast, so we carry multiple 1-gigabyte CF cards and larger when we're shooting pictures. Some of us carry several of them---it's all based on individual needs and styles, and you will have to figure out what yours is likely to be. The good news is: prices on CF cards are dropping.
5. Local retailer vs. mail order --- This is an emotional issue with a lot of people. It depends mainly on your relationship with the local merchant and how deeply he/she is committed to high-end digital photography. There are all kinds of camera stores, and they are definitely not created equal. So once again, the answer to this question really lies within yourself. You have to weigh the value of the local shop to you as a resource for products and knowledge against the reality that you are going to do much better (as a rule) buying online or mail order. I don't particularly trust eBay. It's just too easy to get 'skinned', and I've only used it for hard to find items, and only very cautiously. I don't think I'd buy anything new that way---I only want to deal with companies that have clearly established return policies.
6. Publications. I can't help you much there. I buy everything I can find and read it. My two favorites are Popular Photography & Imaging, and Shutterbug (mainly for the ads). I also buy the Photoshop magazine---so much of digital photography is based on post processing.
You're way ahead of the curve compared to most newbies. You hve SLR experience and you own some lenses. We'll be interested in seeing what you do in the future.
Good luck
Tom
I'm not short. I'm concentrated awesome!
msvadi
Joined Jul 2003
May 21, 2004 09:34 |  #8
I think that in terms of purchasing more equipment you don't need much after you buy the 10D. Just little stuff like compactflash cards (I recommend to get at least 2-3 512MB cards. Check amazon.com, there are always mail-in rebate offers. I just bough a sandisk 512 CF for less than $70 after mail in rebate), extra batteries (you can get generic batteries for about $10. check the ebay, I bought mine from eforcecity (or something like that, they have several ebay IDs) about 6 month ago, it works as good as Canon's), and, may be, the battery grip.
Next, learning Photoshop is essential. Photoshop is not a replacement for shooting skills and good equipment, but with the right post-processing you can really make your pictures stand out. It does not make much sense to buy basic photoshop books. You can find tons of info on the web. Start for example here:
http://luminous-landscape.com …s/instant_photo​shop.shtml (external link)
There some excellent more advanced books, like "Photoshop restoration and retouching" by Katrin Eismann. But even with this book I think that about 2/3 of the techniques described in it can be found on the web.
Finally, getting feedback from knowledgeable people is very important. That's why you have to come back here and post your pictures in "Share" and "Critique" forums. Also, start a gallery and request critique at photo.net. And I'm serious. I started from absolutely nothing less than a year ago. The critique from other forum members really helped me to improve.
Finally, again regarding 10D vs the DRebel. You have some lenses already. If you can afford the 10D, go with it and don't look back.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
May 21, 2004 20:28 |  #9
Welcome to the Forum KarGirlsMom :)
Based on your lens collection.. the 10D is the obvious choice! You will not be disatisfied!
CDS' HOT LINKS
Kinger
Joined Nov 2003
May 21, 2004 21:32 |  #10
Listen I love my DRebel but I have taken some sports photography with it and I will be blunt. It sucks when you try to take shots and you get "BUSY" Don't get the DRebel get the 10D you will be happier with it.
Stephen King
Drebel, EF 17-40L, EF 50, EF 85, EF 100-400L, 550 EX
http://home.comcast.ne​t/~king247 (external link) (randomly changing)
IndyJeff
Joined Oct 2003
May 21, 2004 22:14 |  #11
'nuff said...............
KartGirlsMom
Joined May 2004
May 24, 2004 07:16 |  #12
Thanks for your advice, you all.
So say on a race weekend I shoot 25 rolls of film. What kind of memory card will I need? Goodness, I feel so uninformed--I can delete all the bad pictures in the field right (and knowing me that's 3/4 of the ones I shoot)?--so that frees up space? I have my motorhome with the lap top with me. But that will mean I need to come in off the course to download.
ScottJE22
Joined May 2004
May 24, 2004 07:35 |  #13
I'm new around these parts, but not new to digital photography... I'm in the dSLR market myself right now, but I can comment on a couple of your questions...
You will only have to "dump" from your cards when they fill up. I don't have a digital SLR (yet), but let me comment on one thing: In theory, you can certainly "dump" images while you're in the field, but in practice this is not as easy as it sounds. On my G1, that means switching into "playback" mode, finding the picture, selecting "Delete," confirming the deletion, and changing back to "camera" mode.
And one other consideration -- what looks lousy on the viewfinder may turn out to be the "shot of the day" that could be easily tweaked in Photoshop...
Considering your 25 roll comment... I'm assuming you mean 25 36-exposure rolls. That's a lot of pictures! 900 to be exact! You will definitely want a couple of 512 cards to get started (even then you'll STILL be dumping your images quite frequently!). If going back to the RV to offload to the laptop is not convenient, there are other options that are "in-the-field" type solutions for dumping your images. I've never run out of space on my cards so I've never looked into these, but I'm sure someone else will chime in.
Good luck with your purchase!
dn7elson
Joined Apr 2002
May 24, 2004 07:39 |  #14
With my DRebel, shooting RAW and 400 ISO, the race track images were generally between 6.5 - 7.5 MB in size.
So, if you shot 25 rolls of 36 that would be 25x36x7.0=6.3GB
25 rolls of 24 would be 25x24x7.0=4.2GB
You will also need batteries and/or recharges to allow for this volumn of images. The DRebel gets 400-600 images per charge on its battery, depending upon lots of factors. Less if the image is viewed frequently on the LCD screen or if the flash is used.
So, I would suggest that you have a spare charged battery and 2 - 1 GB (or 4- 512MB) CF cards and download the images to your laptop at lunch or after the days activities. Charge both batteries overnight and you should be good for most situations.
Another option, if you plan to do this much, would be to get one of the portable transfer/storage devices such as the FlashTrax. It is essentially a portable hard drive that allows you do download one CF card while you are shooting with the other. The beauty of this is that you can take it anywhere with you in your bag and transfer the images even in a remote location. You will need to recharge its battery at night as well, and it is quite costly ($400+- depending upon model and HD size-comes in 20GB, 40GB and 80GB versions).
GenEOS
Joined Jan 2003
May 24, 2004 07:47 |  #15
For someone familiar with EOS cameras, the 10D is the only choice...Especially with your lens collection.
Buffer on Drebel stinks. If you are shooting sports.....you will need it.
Daniel Tunstall
http://www.dmtphoto.co​m (external link)
Sports Shooter Member
http://www.sportsshoot​er.com/members.html?id​=2474 (external link)
3,033 views & 0 likes for this thread, 15 members have posted to it.
Total newby
1769 guests, 122 members online
