Is there any accessory that enlarges the viewfinder, to make manual focussing easier? At the moment it seems more down to luck than anything, as i can't get a clear view with the 350D!?!
Cheers
beano Goldmember 4,168 posts Likes: 7 Joined May 2006 Location: Berkshire. UK More info | Jun 03, 2007 15:35 | #1 Is there any accessory that enlarges the viewfinder, to make manual focussing easier? At the moment it seems more down to luck than anything, as i can't get a clear view with the 350D!?! Scott
Cathpah Goldmember 4,259 posts Likes: 5 Joined Jan 2006 Location: Maine. More info | Jun 04, 2007 00:41 | #2 something that works perfectly to enlarge the viewfinder that has no drawbacks and doesn't cost a ton of money? doesn't exist. Architecture
Jun 04, 2007 05:15 | #3 Cathpah wrote in post #3316171 you may want to look into switching focusing screens (not 100% sure that can be done on a rebel) to help with manual focusing. Thanks Cathpath, that's something to look into anyway. Scott
mcmadkat Goldmember 1,059 posts Joined Apr 2007 Location: Scotland More info | Jun 04, 2007 07:06 | #4 Yes, you can get a split circle screen: http://photonotes.org/reviews/viewfinder-screen/
Jun 04, 2007 11:17 | #5 mcmadkat wrote in post #3317178 Yes, you can get a split circle screen: http://photonotes.org/reviews/viewfinder-screen/ Also, don't forget the diopter on the eyepiece ![]() Thanks Mcmadkat. I've been looking at the Diopter today, and i'm starting to think that may be the problem. I've got it pushed to the far left, and it looks pretty sharp, but could perhaps be sharper.. I've been practicing today, shooting slightly left and right of focus, to see if i can find the sharp spot, but so far no luck. Scott
mcmadkat Goldmember 1,059 posts Joined Apr 2007 Location: Scotland More info | Jun 04, 2007 16:05 | #7 MF with the 350D is 75% luck anyway in my experience, the viewfinder is too small to get a clear picture, especially when using 300mm at f8 stop down, darn dark!
oldsquawk Member 246 posts Joined May 2007 More info | Jun 04, 2007 16:19 | #8 Be sure that the diopter adjustment is set correctly for your eyesight. If the diopter adjustment is not correct you will never see a sharp image on the focusing screen. 1) Point your lens at the clear, blue sky and throw the sky out of focus. 2) Look at the little squares in the viewfinder that designate the autofocus points. 3) Rotate the diopter adjustment wheel until the little squares are in best focus. You're done. Makes manual focus so much more accurate. If, for some reason, there isn't enough diopter adjustment to compensate for your eyesight, you can buy eyepiece cups with an additional diopter lens installed. Between the diopter lens in the eyecup and the diopter lens in the viewfinder you will be able to adjust the focus to suit your eyesight. Unless of course, you are totally blind and echo-locate! oldsquawk
Jun 04, 2007 18:49 | #9 baxtefer wrote in post #3318501 see this thread: https://photography-on-the.net …t=298724&highlight=eyecup Thanks for the link Baxtefer, interesting thread. That might be a route to take. mcmadkat wrote in post #3319843 MF with the 350D is 75% luck anyway in my experience, the viewfinder is too small to get a clear picture, especially when using 300mm at f8 stop down, darn dark! Having said that, I am getting used to it, its just not as good as a dedicated MF camera. I'm hearing that! oldsquawk wrote in post #3319923 Be sure that the diopter adjustment is set correctly for your eyesight. If the diopter adjustment is not correct you will never see a sharp image on the focusing screen. 1) Point your lens at the clear, blue sky and throw the sky out of focus. 2) Look at the little squares in the viewfinder that designate the autofocus points. 3) Rotate the diopter adjustment wheel until the little squares are in best focus. You're done. Makes manual focus so much more accurate. If, for some reason, there isn't enough diopter adjustment to compensate for your eyesight, you can buy eyepiece cups with an additional diopter lens installed. Between the diopter lens in the eyecup and the diopter lens in the viewfinder you will be able to adjust the focus to suit your eyesight. Unless of course, you are totally blind and echo-locate! ![]() lol! Scott
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Jun 06, 2007 13:35 | #10 If you don't need glasses except for close work, you shouldn't have any trouble adjusting the diopter setting on the VF to get a clear image. What power reading glasses did they give you? If you need a -3 or greater adjustment you'd be having serious problems focusing your eyes closer than 5-6 ft away. Jon
Jun 06, 2007 16:00 | #11 The glasses aren't strong at all!?! With the Diopter, i keep turning the wheel to the left and it seems to get sharper and sharper. There doesn't come a point where it looks like it's getting soft again!?! Scott
nadtz Goldmember 1,483 posts Likes: 1 Joined Dec 2005 More info | Jun 06, 2007 20:13 | #12 nikons dk-21M is very useful, I had one on my 350D and have one on my 30S. That ebay.uk auction looks to be the same part.
Reaperman Senior Member 473 posts Joined May 2007 Location: London, England More info | Heh Beano. I also had a little trouble at first with my 400D. I wear glasses for driving/distance only and thought I would need a corrective lens made.
Jun 07, 2007 06:00 | #14 nadtz wrote in post #3333443 nikons dk-21M is very useful, I had one on my 350D and have one on my 30S. That ebay.uk auction looks to be the same part. Cheers nadtz, i'm still playing with the idea of going down this route. The Diopter was the cheapest option, so i'll try that first, but if that fails i'll give the dk-21m a shot. Reaperman wrote in post #3335020 I was almost happy but then bought an EP-EX15 eyepiece extender. I left the lens in it (unlike a lot of people appear to do) and I have found it improved my focussing technique. Don't ask me why, it is just more comfortable not having to press my eye, nose and anything else right against the screen. Thanks Reaperman. I don't really have any issues with pressing my nose against the camera, as i tend to shoot with my face slightly turned away anyway. With the lens left in, are you not losing some light? Everything i've read about the extender, says the viewfinder becomes darker with the lens in. If it's helped for you, i'll definitely keep it in mind though... It's a damn site cheaper than a 5D lol! Scott
Reaperman Senior Member 473 posts Joined May 2007 Location: London, England More info | Can't say I've noticed any difference with light or lack of it.
| Latest registered member is semonsters 1054 guests, 103 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
