c0ntr0lz wrote:ok so weighted metering issue that is not correctable on the camera
alright here are some pix from my walk today
all the detail are on each image
| HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
They both look fine, really. You're shooting evaluative so your metering depends partly on the active focus point. In the top picture, I'm guessing that your active focus point was right in those trees beyond the dam. In the second one, you caught some sky in that metering zone so the camera stopped the shutter down a bit (1 stop).
A couple of points - first, you probably want to keep your contrast at "normal" most of the time. Why? Because it makes the subtle change of making dark things a little darker and light things a little lighter. In other words, it tends to eat up a little of your dynamic range. On a really wide-ranging photo, you could lose detail in both bright and dark areas at the same time.
Also, keep an eye on the histogram - if the shot looks extreme on either end, adjust exposure compensation 1/3 to 1 stop or so in the other direction and retake the shot. Its digital so the shot is free, and you have a good opportunity to experiment.
