Thread started 04 Jun 2007 (Monday) 20:01
85.9 vs 100.2. Would you consider them different?
Pasukun
Jun 04, 2007 20:01 |  #1
I would like to ask you all.
Beside the obvious FL diff..
Would you consider 85.8 and 100.2 to be any different?
I was trying to help this guy out so he can make the best choice for his need.. and this one dude keep insisting that the 100.2 is far superior lens than 85.8.
Saying 85.8 is not even in the same league of quality as 100.2..
I KNOW what 85.8 and 100.2 look like.. and they look almost identical(if not 100%).
The performance of both lenses are also very much the same.
I got the pictures and charts from photozone.de so you can see them side by side.
http://img364.imagesha​ck.us/img364/2137/100v​s85ps9.jpg (external link)At the wide open, 100.2 is definitely bit sharper especially around the border.
But every 1/3 stop you tighten down the 85.8.. the sharpness and contrast dramatically goes up.
By the time you tighten down to 2.8 and beyond.. they perform so much alike it is pointless to talk about which one is better.
Now I don't mind if the guy choose either 85.8 or 100.2.. they are both equally excellent.
But I didn't want him to make a decision based upon this whacky dude's claim.
"the things we touch have no permanence.. as there is nothing we can hold onto in this world.. only by letting it go can we truly possess what is real.."
My Gears
thekid24
pro-zack-lee
Jun 04, 2007 20:04 |  #2
Different only in focal length, bout it:D
angryhampster
"Got a thick monopod?"
Jun 04, 2007 20:06 |  #3
thekid24 wrote in post #3321129 (external link)
BS!!
The 100 is 1/3 stop slower. :lol:
Steve Lexa
Iowa City Wedding Photography (external link)
thekid24
pro-zack-lee
Jun 04, 2007 20:10 |  #4
angryhampster wrote in post #3321140 (external link)
BS!!
oh YEAH!!!.....D'oh
angryhampster
Jun 04, 2007 20:21 |  #5
thekid24 wrote in post #3321170 (external link)
oh YEAH!!!.....D'oh
hehe...In all honesty though, I'd love to use the 100 f/2. I had an 85 f/1.8 for about 3 months, but sold it because I just didn't need that focal length and rarely used it. However, when I did use it, it was a real gem. Well-built, fast and accurate AF, and beautiful colors and contrast. The only downside I ever found to it was the chromatic abberations when shooting wide open...which were rather terrible.
Steve Lexa
Pasukun
Jun 04, 2007 20:39 |  #6
angryhampster wrote in post #3321242 (external link)
Right. I agree.
I would personally have bought 100.2 if I didn't plan to get 135L in the future.
But still, I have nothing to complain about the performace of the 85.8 and the fantastic result it delivers.
It did more than the expectation I had for it.
My Gears
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Jun 04, 2007 21:12 |  #7
In real world terms, I'd doubt you'd see much if any difference between the two lenses.
I'd let the focal length and price determine which one to get.
Gallery: http://tomyi.smugmug.c​om/ (external link)
Lostboy77
Jun 04, 2007 23:50 as a reply to  @ Tee Why's post |  #8
The only "real" quality difference between these two is the 85 shows some CA when shot wild open that the 100 does not exhibit. they both have identical construction except that the 85 has one extra element that allows for the wider focal length and it's this element that causes the added CA. The same problem would exist between the 135L and 200L except that the Ls have special glass that work to remove CA distortion. I have the 100/2 and find it to be an amazing lens. When I had a 1.6 crop camera I did find the length to be a little long but on the 5D it's a perfect portrait lens.
Canon EOS M50 - EOS M
EF-m 15-45mm IS STM - EF-m 18-55mm IS STM - EF-m 22mm f/2 STM
EF-s 55-250mm IS STM - EF 50mm f/1.8 STM - Speedlite 430EX II
TheGreatDivorce
Jun 05, 2007 12:03 |  #9
What's an 85.8? Doesn't seem that hard to write, "f/1.8" ...
The 85 is better, IMO ... if you want equivalent framing to the 100 f/2, then take a step forwards. If you want to shoot at f/2.0, the do it. The 100 can't shoot at f/1.8, though.
gorby
Jun 05, 2007 12:23 |  #10
is the difference in focal length really equate to about 'a step'?
That's really interesting, I never thought about it that way before. (I myself honestly have no idea, as my first telephoto is only in the mail as we speak)
5D MKII | 650D [SIZE=2][SIZE=2][SIZE=​1]| 350D (RIP)
17-40 f/4L | 70-200 f/4L | 50mm 1.8 | 18-135 STM IS
My work (external link)
Wilt
Jun 05, 2007 12:34 |  #11
gorby wrote in post #3325139 (external link)
15% difference between the FL. If the distance was 10', you would move forward to 8.5'. Both lenses would see FOV of 1.78x2.74' with the 100mm at 10' from subject or with the 85mm at 8.5' from subject...less than one 30" standard step.
Of course, when the distances get longer, the differential gets greater, and you would need to be the Jolly Green Giant to take only one step! The differential at 100' is 15'; at 1000' it is 150'
Of greater concern, though, is if you wanted to shoot a tight headshot, cropping in the camera. With the 100mm you could shoot at a comfortable yet close distance, whereas the 85mm might put you uncomfortably close for the same framing or for placement of lights. 5' vs 4' shooting distance.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jun 05, 2007 12:46 |  #12
@ 11 MP or more the lower resolving power of the 100mm becomes noticeable,. ie: the 85mm is better if you have the sensor to show the fact.
CDS' HOT LINKS
wimg
Jun 05, 2007 13:10 |  #13
CyberDyneSystems wrote in post #3325257 (external link)
I think that would be caused by specimen variation, not by this slight difference. Furthermore, if you reason this way, the 100 F/2 is better at larger apertures than the 85 F/1.8, because the 100 has better corner resolution up to F/4.
60 lines at 8 MP difference equate to less than 3 lines or 1.5 lp/mm. Apart from this being easily within sample variation, and certainly within measuring accuracy (what was it? 10%? 15%), you wouldn't even be able to see this difference at anything considered normal viewing distances, or 100 % even.
Good primes resolve between 250 and 400 lp/mm at F/4. 11 MP is not going to add the resolution you need to get to this number, and neither is the dynamic range of the sensor good enough to capture this type of resolution with the current state of technology. We're still sensor limited, not lens limited, regardless what people say out here or there, or wherever. It is only pixel peeping that makes lens aberrations more obvious, that's all.
Kind regards, Wim
Pasukun
Jun 05, 2007 13:18 |  #14
Lostboy77 wrote in post #3322327 (external link)
I know 85.8 definitely have a CA at wide open, but it gets better as you tighten it down.
2.2 and beyond the CA becomes really well controlled.
TheGreatDivorce wrote in post #3325050 (external link)
I'm sorry if it bugged you, but I like to keep it simple, so 85.8 it is.
Wilt wrote in post #3325185 (external link)
I agree.
I would definitely use 100mm(or 135mm) on a FF body as 85mm is indeed bit too close.
But on the APS-C body, 85mm is more ideal FL than 100mm IMHO.
At least for me.
My Gears
Pasukun
Jun 05, 2007 13:31 |  #15
wimg wrote in post #3325387 (external link)
Kind regards, Wim
Even at f/2.8. The border resolution on both lenses are so very close.
The border resolution on the 85.8 appears to be lacking more than it actually is..
Because the center resolution of the 85.8 is spiking bit higher than 100.2's center resolution, while the border resolution is bit less.
But over all.. I would say they are just about identical.
And it will be really hard to tell the border resolution difference when you actually compare the pictures side by side. Especially if they were taken with APS-C sensor.
My Gears
3,320 views & 0 likes for this thread, 18 members have posted to it.
1257 guests, 166 members online
