I'd appreciate the views of the experts here about my White Balance problem.
Exhibit A is a pano shot in the Lake District. I shot RAW and sampled the white and grey clouds in several places using the eye-dropper tool in order to establish an appropriate White Balance. I'm pretty happy with the results.
![]() | Byte size: ZERO | Content warning: NOT AN IMAGE |
Exhibit B is another pano, shot 19 minutes later from a vantage point about 1km further along the path. My procedure was the same: shoot RAW, sample the white and grey clouds in several places to establish the WB. Again, I'm pretty happy with the results.
But you can immediately see my problem: the two pictures have completely different colours! As far as I recall, the light had not changed appreciably in the intervening time. The two shots were taken at 14:19 and 14:38, and sunset would have been around 17:36, so that shouldn't be an issue. And as you can see, the extent of cloud cover had not changed much.
Any suggestions? Is my technique faulty, and if so what should I do differently? Are the colour differences liklely to be real, and if so why? And does it really matter? Is there a "correct" WB, or is it all in the eye of the beholder?
But also consider your angle. It's not the exact same shot. It's 2 different shots, and the sun is shooting through the clouds slightly different. And being at different times of the day (although slight) does have an impact. You also may not have sampled a perfectly white spot on one image or the other.
