Thread started 05 Jun 2007 (Tuesday) 22:07
How to avoid bad printing crop??
jmoe816
Jun 05, 2007 22:07 |  #1
I had one photo printed from yorkphoto.com in (1) 4x6, (1) 5x7, and (1) 8x10.
The 4x6 turned out very nice, the 5x7 and 8x10 however were cropped and are missing part of my subject. Especially the 8x10.
Is there anything I can do to avoid this?
cdifoto
Don't get pissy with me
Jun 05, 2007 22:10 |  #2
jmoe816 wrote in post #3328014 (external link)
Crop to the appropriate dimensions before uploading/ordering.
RuggerJoe
Jun 05, 2007 22:28 |  #3
Each of those print sizes have different aspect ratios. Aspect ratio is the ratio of width to height.
4x6 is 2:3
5x7 is 5:7
8x10 is 4:5
The only thing you can do is like cdifoto said is to crop it yourself so that your not leaving it up to some machine to decide what to chop off. This means uploading a file for each aspect ratio, or only selection print sizes that match the aspect ratio of you file
But sometimes you can't crop without loosing something important. Then another option is to use a company that doesn't crop, but adds white space when the aspect ration of the file doesn't match the printed aspect ratio. I believe Winkflash gives you the option to add white space. They will put a white bar at the top and bottom or on the sides so the whole image fits in the print dimensions.
Joe
Comments / critiques always welcome.
http://www.flickr.com/​photos/ruggerjoe/ (external link)
Canon 350D
EF-S 17-85 IS USM | EF 50 1.8 | EF 70-300 IS | 580EX | a couple of kit lenses
All of which are all better than my skills.
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Jun 05, 2007 23:39 as a reply to  @ RuggerJoe's post |  #4
It is the same problem that Cinderella's Sisters faced. It just WONT fit, no matter what you do, 3x2 just is not 5x4.
The term is Aspect Ratio. The ratio of height compared to width.
Such as it is, you have only 4 choices:
Example 1) Print the whole shot in 3x2 ratio, get a 3x2 ratio frame and be done with it.
Example 2) Print it in 3x2 ratio on 5x4 ratio paper. This will result in un-printed margins on the top and bottom. Those are the white margins top and bottom that you see.
Example 3) Crop the shot to 5x4 ratio and print it. You will use all the paper, but, as you said, you lose some of the image. The parts that will be cropped off are the gray areas left and right.
4) Skew the original shot to 83.33% of the width, and print it on 5x4 ratio paper. This will distort the image, but some subjects complain that the camera adds weight anyway, so maybe it is a good choice.
So, until the Big Crunch a couple hundred billion years from now - when the Newtonian laws of physics break down and length is meaningless - you are stuck with these 4 choices.
Rad
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
jmoe816
Jun 06, 2007 11:36 |  #5
Thank you, this information has been very helpful!
Is there an easier way to crop to exact ratios in photoshop without using the crop tool and making the precise dimentions?
In2Photos
Jun 06, 2007 12:00 |  #6
jmoe816 wrote in post #3330859 (external link)
There is a drop down menu on the left (when you select the crop tool) with preset dimensions.
Or you can use the Marquee tool but I prefer the crop tool.
Current Gear and Feedback
spcalan
Sep 27, 2007 16:23 |  #7
aaaaa
Alan Hicks
Canon 5D w/Grip/ Canon Rebel 6mp ( back-up ) - Sold
28-135 USM IS / 50mm 1.4 / - Sold
Bunches of Lexar Pro 2GB/4Gb cards - Still got
1,725 views & 0 likes for this thread, 6 members have posted to it.
2682 guests, 170 members online
