Thread started 23 May 2004 (Sunday) 17:48
after 2 weeks
sammy41
Joined May 2004
May 23, 2004 17:48 |  #1
ok A 80 will be here wensday, so after 2 weeks of using your new a80 what are the 2 most needed items? and could you tell me what the deference between a cf and a cf1 card is
sammy
Giant
Joined May 2004
May 23, 2004 21:45 |  #2
As far as I know, the speeds are what is different, there may be more things. But get a tripod and a LARGE capacity CF card.
Gear list : Canon Powershot A80, Nikon D70, 18-70mm Kit Lens, Sigma 170-500mm.
flipper321
Joined Apr 2004
May 24, 2004 04:50 |  #3
High capacity rechargeable Nimh batteries and charger.
Giant
Joined May 2004
May 24, 2004 06:19 |  #4
Yes, I also got some, I got 2100mAh ones. They are great!
Mac22
Joined Apr 2004
May 26, 2004 08:54 |  #5
Hi sammy41!
You asked about differences between CF and CF I cards -- actually they are designated specifically as CF Type I and Type II -- with the former being thinner and the latter being thicker.
Type II is the same size as Microdrive.
My G3 will handle both types and my S400 will only handle Type I.
Likely your A80 will only handle Type I also but check!
In case your next question is what brand is best -- I somehow picked-up that Ridata and SimpleTech are good brands and use both of them with the Ridata in the G3 and the SimpleTech in the S400 -- I keep them separate so as not to mess up the image count.
Seems like I have heard many stories of failure with the standard SanDisk line and even Lexar and also Viking but that is only recollection and I am sure many use those brands without problem.
I would also recommend going with 2 smaller size CF cards instead of 1 large under the concept of not having all your eggs in the same basket. let your shooting habits be the deciding factor for what THAT size is.
Another tip: Disable the (Default) AiAf feature when you set it up the first time -- focus will be better without it!
Enjoy your new Canon!
Mac22
1,922 views & 0 likes for this thread, 4 members have posted to it.
after 2 weeks
1020 guests, 105 members online
