Thread started 07 Jun 2007 (Thursday) 19:04
What is your favourite process?
PG07
Jun 07, 2007 19:04 |  #1
Being new to photoshop I find I use only a small range of PP because I only know a limited amount. I figure most here know more than me but do you follow a general path like I do now and stick to a similar method each time?
"The poetry of photgraphy will always be more important than mechanics of the camera... you see the picture is taken with the eye,the heart.The most sophisticated camera in the world can never replace this." Jacques-Henri Lartigue
Peter:) canon400D 18-55 , 50mm 1.8,75-300,Sigma 17-50 F/2.8 EX OS HSM , 430EX II ,Lowepro slingshot 200AW. Sony a6000 , Sigma 30mm 1.4 e-mount, 17-50 kit and 55-200 kit.
R ­ Hardman
Jun 08, 2007 00:26 |  #2
Curves, level, saturation, and sharpening. As far as sticking to a similar methed, I don't. Each photo is different thus processed different. Welcome to the forum! You will learn tons here.
"Whatever you can do to avoid Photoshop is worth it"
EOS 7D, EOS 350D, EF 17-40mm f/4L USM, EF 70-200mm f/4L USM, EF-S 18-55mm f/3.5-5.6 USM (Kit)
Rick's Digital Desert (external link)
thekid24
pro-zack-lee
Jun 08, 2007 00:40 |  #3
The look I go for is a desaturated, grainy, dark shadow image. So it starts off with a desaturating, then levels adjustments, add a noise filter, then a USM filter to make the noise pop. The if needed Ill go over the highlights with a soft dodge.
Now to get nice contrast,sharp, pro looking photos I do what Hardman does.
PG07
Jun 08, 2007 07:22 as a reply to  @ thekid24's post |  #4
I just had a little dabble in colour. Lost edited images in layers 4 times somehow:confused: Rushed this one but it is fun:cool:
Thanks for the replies:)
freebird
Jun 08, 2007 09:32 as a reply to  @ PG07's post |  #5
One suggestion.....I always make a copy of the original. Then work on that in PP. Takes awhile to learn Photoshop. Hang in there practice, practice practice.
Good Luck
Chuck
663 views & 0 likes for this thread, 4 members have posted to it.
2789 guests, 159 members online
