Hi all!
I have shot some jpeg's with 20D set to sRGB can I change them to Adobe RGB? or is it too late.
Thanks.
Tony.
twistedpixels Senior Member 457 posts Joined Apr 2006 Location: East Coast Australia More info | Jun 08, 2007 20:08 | #1 Hi all! 20D,400D, A2, G7, Powershot A40, 550EX Flash, 70-200 2.8L, 28-105 USM, 28-135 IS USM, 50mm 1.4 USM, 18-55(kit) BGE2, Expodisc, Manfrotto 141RC tripod, Manfrotto 679B monopod, A stack of Sandisk CF cards, many Lowepro bags and an Extremely limited knowledge of taking good photographs.
TeeWhy "Monkey's uncle" 10,596 posts Likes: 5 Joined Feb 2006 Location: Pasadena, CA More info | Jun 08, 2007 20:18 | #2 I think it's too late. FWIW, if you shoot in RAW, as you convert to JPEG you can select the color space and if you saved the RAW shots, you can reconvert to JPEG with different color spaces. Gallery: http://tomyi.smugmug.com/
twistedpixels THREAD STARTER Senior Member 457 posts Joined Apr 2006 Location: East Coast Australia More info | Thanks TEE WHY. 20D,400D, A2, G7, Powershot A40, 550EX Flash, 70-200 2.8L, 28-105 USM, 28-135 IS USM, 50mm 1.4 USM, 18-55(kit) BGE2, Expodisc, Manfrotto 141RC tripod, Manfrotto 679B monopod, A stack of Sandisk CF cards, many Lowepro bags and an Extremely limited knowledge of taking good photographs.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Jun 09, 2007 01:05 | #4 Why would you want to? Unless they MUST be in Adobe RGB leave them as-is. Use "convert to profile" (NOT assign). Plenty of pros shoot sRgb JPG and have great results. The conversion is very slightly destructive but not so much a human eye could probably notice it, do it a dozen times then maybe, but only maybe. The loss is probably more theoretical, i've never tried it. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
twistedpixels THREAD STARTER Senior Member 457 posts Joined Apr 2006 Location: East Coast Australia More info | Jun 09, 2007 03:24 | #5 tim wrote in post #3346809 Why would you want to? Unless they MUST be in Adobe RGB leave them as-is. Use "convert to profile" (NOT assign). Plenty of pros shoot sRgb JPG and have great results. The conversion is very slightly destructive but not so much a human eye could probably notice it, do it a dozen times then maybe, but only maybe. The loss is probably more theoretical, i've never tried it. They are photos I shot in sRGB quite a while ago and the people they are going to want them in adobe RGB. Thanks Tim. 20D,400D, A2, G7, Powershot A40, 550EX Flash, 70-200 2.8L, 28-105 USM, 28-135 IS USM, 50mm 1.4 USM, 18-55(kit) BGE2, Expodisc, Manfrotto 141RC tripod, Manfrotto 679B monopod, A stack of Sandisk CF cards, many Lowepro bags and an Extremely limited knowledge of taking good photographs.
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Jun 09, 2007 05:41 | #6 Technically, you can do the conversion (in order to satisfy those people) but practically you don't gain anything from it since the computer can't restore the colors that were discarded by the compression to sRGB. Elie / אלי
DavidW Goldmember 3,165 posts Likes: 1 Joined Jul 2005 Location: Bedfordshire, UK More info | Jun 09, 2007 05:52 | #7 I think you're better off explaining that the pictures are in sRGB. 8 bit sRGB to 8 bit Adobe RGB is a destructive transformation for sure, and may just lead to some posterisation as you have the same 0-255 R, G and B space representing a wider range of colours.
mantra Goldmember 1,617 posts Joined Nov 2006 Location: Italy, Rome More info | never understood in poor words the gain to use adobeRGB canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
DavidW Goldmember 3,165 posts Likes: 1 Joined Jul 2005 Location: Bedfordshire, UK More info | Jun 09, 2007 07:06 | #9 Adobe RGB has a wider gamut than sRGB - if I remember rightly, particularly in the greens and blues. Many inkjet printers, particularly at the higher end, share this wider gamut - so by using Adobe RGB, you can get these shades that you'd miss out on if using sRGB.
kevin_c Cream of the Crop 5,745 posts Likes: 4 Joined Mar 2005 Location: Devon, England More info | Jun 09, 2007 07:19 | #10 DavidW wrote in post #3347454 Adobe RGB has a wider gamut than sRGB - if I remember rightly, particularly in the greens and blues. Many inkjet printers, particularly at the higher end, share this wider gamut - so by using Adobe RGB, you can get these shades that you'd miss out on if using sRGB. The disadvantage is that without proper colour management, Adobe RGB images look wrong - for the web, you should use sRGB, for example. If you don't understand colour management, your best bet is to stick with sRGB. David Thats what I would normally advise. -- K e v i n --
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Jun 09, 2007 07:22 | #11 DavidW wrote in post #3347286 The only way you'll get colours in the image that are outside the sRGB gamut is if you're post-processing them into the image - if colours in the Adobe RGB gamut but outside the sRGB gamut were present in camera, the camera will have moved them inside the sRGB gamut. I think Perceptual rendering intent will give you colors that are outside sRGB Gamut, since the entire image is 'remapped'. It doesn't mean that they represent the actual (real life) colors though (In fact: Likely not)... "I think the idea of art kills creativity" - Douglas Adams
DavidW Goldmember 3,165 posts Likes: 1 Joined Jul 2005 Location: Bedfordshire, UK More info | Jun 09, 2007 08:02 | #12 René Damkot wrote in post #3347495 I think Perceptual rendering intent will give you colors that are outside sRGB Gamut, since the entire image is 'remapped'. It doesn't mean that they represent the actual (real life) colors though (In fact: Likely not)... Perceptual will remap all the colours. I'm honestly not sure whether that would map anything to colours outside sRGB gamut; normally perceptual is used to compress the colours in a wider gamut space into a narrower colour space. sRGB to Adobe RGB using perceptual is 'backwards'; it's possible that you'll finish up with false colours that are sometimes outside the sRGB gamut. I'm not enough of a colour management guru to be sure.
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Jun 09, 2007 08:17 | #13 René Damkot wrote in post #3347495 I think Perceptual rendering intent will give you colors that are outside sRGB Gamut, since the entire image is 'remapped'. It doesn't mean that they represent the actual (real life) colors though (In fact: Likely not)... Remapping colors going from sRGB to Adobe RGB shouldn't be a problem because all the sRGB colors should be present in the Adobe RGB color space. It's when you go from a larger to a smaller gamut where perceptual rendering can becomes a "problem" due to possible color shifts. ...Leo
gparvan Senior Member 788 posts Likes: 1 Joined Oct 2006 Location: Seattle, WA More info | sRGB is a smaller color space than aRGB, but that doesn't mean there isn't colors outside the gamut of aRGB.
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Jun 09, 2007 23:08 | #15 gparvan wrote in post #3349942 sRGB is a smaller color space than aRGB, but that doesn't mean there isn't colors outside the gamut of aRGB. Perceptual rendering intent will try and keep the overall colors the same and move the destination "out of gamut" colors to the closest color match to source. Relative Colorimetric rendering intent will match the "white" and clip the destination "out of gamut" colors. So I believe the rendering intent you choose should be based on the color content/range of you picture i.e., try it both ways and go with what suits you! Then can you point out what those colors are that sRGB has that's not in the Adobe color space? I'm looking at both color spaces simultaneously from all angles and I can't find any sRGB color that goes outside the color gamut of the Adobe RGB color space. The Adobe RGB color space completely engulf the sRGB color space as far as I can see. ...Leo
| Latest registered member was a spammer, and banned as such! 2856 guests, 161 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
