britt777 wrote in post #3356233
PS automatically adjusted the res for me.
If you were using the crop tool, just clear out the resolution box as shown in the example below. As a result, Photoshop will not resample the image but leave the current resolution in the document when cropped.
As a general rule; 180dpi & up is sufficient for Newspaper prints, etc and 220dpi & up is best for magazines & higher quality printing. 300dpi is best for high quality photographic printing. To be safe, stick with 300dpi on any print unless filesize is an issue. For your needs, you'll want to resample your image for a quality print; unfortunately, quality may suffer a bit because Photoshop adds its own pixels when upsampling. You may need to use Unsharp Mask or other post processing to regain the crispness of your image if there's a substantial difference. The overall results of upsampling will be better for an enlargement because you won't have the ugly pixel blockiness associated with an undersampled, oversized image...hope that makes sense?
As far as the best way to effectively increase the size of an image, Eyecandy offers a brilliant plugin for Photoshop that does just that. You could download the free trial version and apply the effect to your image to see the results. If printing enlargements are a large part of your business, it may be a tool worth investing. http://www.eyecandy.com/blowup/index.html
