Thread started 11 Jun 2007 (Monday) 20:13
EMERGENCY Polarizer stuck on lens problem
Billginthekeys
Billy the kid
Joined Nov 2005
Jun 11, 2007 20:13 |  #1
Okay guys, im leaving for alaska in the morning, and wouldnt you know it but my stupid polarizer is stuck to my 24-105. obviously with the circumstances as they are i cant order up a filter wrench set, and i need immediate assistance.
Mr. the Kid.
Go Canes!
My Gallery (external link)My Gear
what the L. just go for it.
MDJAK
Jun 11, 2007 20:15 |  #2
Stupid solution that probably only applies to dummies like me, but the same thing happened to me recently.
You know what the problem was? I was turning it the wrong way. Give it a try.
Good luck.
mark
transcend
Joined Oct 2004
Jun 11, 2007 20:17 |  #3
vice with softjaws, rubber band style pipe wrench, channel locks etc.
http://www.fraserbritt​on.com (external link)
JimAskew
Gallery: 6 photos
Jun 11, 2007 20:17 |  #4
Billginthekeys wrote in post #3361286 (external link)
Try the rubber band around the filter edge trick...it worked for me...gives you a much better grip.
Jim -- I keep the Leica D-Lux 7 in the Glove Box just in case!
7D, G5X, 10-22MM EF-S, 17-55MM f/2.8 EF-S IS, 24-105MM f/4 EF L, Leica D-Lux 7
dekalbSTEEL
Jun 11, 2007 20:17 |  #5
Have you tried one of those rubber jar opener thingy's from the kitchen?
Grippy 30D, Tokina 300f4, Sigma 18-50f2.8, Canon 70-200f4L, thrifty50mkI, PM7500DX
Jon Gee Photography.com (external link)
Billginthekeys
Billy the kid
Joined Nov 2005
Jun 11, 2007 20:19 |  #6
yea ive tried a grip wrench. did nothing at all. it just turns on the roating part of the polarizer no matter how much you tighten it or put it toward the bottom.
Mr. the Kid.
Go Canes!
Jim7226
Jun 11, 2007 20:25 |  #7
Maybe it's too hot in Florida and you need to put the lens (protected) in the freezer for a short while so the metal contracts (and possibly loosens the threads enough). Do this if all else fails...but try the other suggestions first. Good luck...and have fun in Alaska!! :)
Jim B.
johnstoy
Jun 11, 2007 20:31 |  #8
Billginthekeys wrote in post #3361331 (external link)
I hate to say this but I had the same thing happen with my 77mm B& W on a metal filter case lid...
Used a Large Vise and Channel Lock Pliers on top of the rubber bands...
Got it off but after all was done I scratched up the lens washing the oil lubricant I had to use off it...
:evil:
John Stoy
www.poconophotos.com (external link)
My Gear List
"Are you only Looking or actually Seeing", from Microbiology 101.
Billginthekeys
Billy the kid
Joined Nov 2005
Jun 11, 2007 20:39 |  #9
Jim7226 wrote in post #3361376 (external link)
already put it in the fridge... didnt do anything. im afraid its cross threaded but i really hope not...
Mr. the Kid.
Go Canes!
WMS
"Escargot on the Hoof"
Jun 11, 2007 20:55 |  #10
Have you tried to use a wide rubber band to give you additional 'grip' on the filter? Hopefully this will allow you to turn the filter threads as well as the rotating ring. Polarizers can be difficult.
WMS
I'm just a simple maker of love charms and tokens,who occasionally takes a picture or two.
Gear list: more toys than I need, Fewer than I want.
Billginthekeys
Billy the kid
Joined Nov 2005
Jun 11, 2007 20:57 |  #11
yep... still stuck....
Mr. the Kid.
Go Canes!
WMS
Jun 11, 2007 21:01 |  #12
Well there is always the nitroglycerin solution :p But I don't recommend it unless you are very very good with things which go bang.
WMS
Billginthekeys
Billy the kid
Joined Nov 2005
Jun 11, 2007 21:04 |  #13
crap..... this sucks.... i dont so much mind having the polarizer on my 24-105 that much.... its the not being able to have it on any other lens that sucks....
Mr. the Kid.
Go Canes!
ramblingman
Jun 11, 2007 21:07 |  #14
You're screwed. JK. Try to blow some compressed air around it, vice it, use a pipe wrench (or channel lock pliers) after you've wrapped it in a rubber band, the lens, that is. Use extreme caution. Would WD-40 carefully used ruin it?
Canon 20D / Canon 70-200mm f2.8L IS USM / Canon 18-55mm f/3.5-5.6 USM / Canon 50mm f1.8 II / Canon 85mm f/1.8 USM / Sigma 10-20mm F4-5.6 EX DC HSM / Tamron 28-300mm f/3.5-6.3 XR Di / Speedlight 580EX / Quantaray Table Tripod / Manfrotto 676B Monopod / Manfrotto 3021 Pro Tripod with 488RC2 Head / Lowepro Sling Shot 200 AW /
EricL
Jun 11, 2007 21:08 as a reply to  @ Billginthekeys's post |  #15
I have had that same problem. I have found that if I actually tighten it just a smidge then spin it the other way it comes off. Hope this Alaska weather holds out for you cause it has been flat BEAUTIFUL!! EricL
[SIZE=2]:lol: EricL :lol:
farwhitenorth.com (external link)
5,667 views & 0 likes for this thread, 30 members have posted to it.
655 guests, 125 members online
