I have been having a problem with my 2500 mAh rechargeable Energizers. They range in age from 12 months to 16 months old. They are not holding a charge for very long. I contacted the company and they recommended that I use a charger that has a trickle charge feature. They said:
"That way you can leave your batteries in the charger and they will be topped off with a low rate charge. You should occasionally drain your batteries completely by letting them run down to the point where the device will no longer work."
I am currently using the Energizer compact charger. Does anyone have a recommendation regarding a trickle charger? Would the Energizer one be a good bet?
How do others drain (run down) their rechargable batteries?
Any advice would be appreciated.
