Used my Tamron 28-75mm f/2.8 XR Di LD and 430EX. Let me know what you guys and gals think.
Thanks!
1.
2.
3.
4.
5.
xzombiex Senior Member 273 posts Likes: 20 Joined Dec 2006 Location: Bay Area, CA More info | Jun 15, 2007 11:20 | #1 |
johnstoy Cream of the Crop 6,646 posts Likes: 7 Joined Aug 2006 Location: Poconos, PA USA More info | Jun 15, 2007 11:57 | #2 Toss a number in between the pics, so we can address them individualy... How did you use the flash and which lens did you use? John Stoy
Jun 15, 2007 12:12 | #3 I used my Tamron 28-75mm f/2.8 XR Di LD as stated above, and the flash I used I sorta played around with. It was in auto mode using second curtain sync and ettl mode. The head positioning depended on where I was shooting from, as you can see, I had to work with really harsh shadowing so I had to find ways to brighten up things without adding to the brightness of the outside light.
johnstoy Cream of the Crop 6,646 posts Likes: 7 Joined Aug 2006 Location: Poconos, PA USA More info | Jun 15, 2007 12:27 | #4 xzombiex wrote in post #3382774 I used my Tamron 28-75mm f/2.8 XR Di LD as stated above, and the flash I used I sorta played around with. It was in auto mode using second curtain sync and ettl mode. The head positioning depended on where I was shooting from, as you can see, I had to work with really harsh shadowing so I had to find ways to brighten up things without adding to the brightness of the outside light. I see some are with flash and a couple are without... John Stoy
Suicidenote Senior Member 672 posts Joined Aug 2006 Location: Los Angeles, CA More info | Jun 15, 2007 19:23 | #5 #2 - try to crop out the back 1/2 of the singer Gear List:
| Latest registered member is Thunderstream 1839 guests, 101 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
