Thread started 15 Jun 2007 (Friday) 13:37
Ultimat Macro?
Overkill
Jun 15, 2007 13:37 |  #1
Hello
Ive been trying (for a long time) to get some decent Macro Shots.
http://www.kiek.info …%20Animals/slid​es/017.asp (external link)
http://www.kiek.info …%20Animals/slid​es/020.asp (external link)
http://www.kiek.info …%20Animals/slid​es/023.asp (external link)
Any hints and tips for me to improve my work!!
Thanx
Richard:)
Canon EOS 40D Gripped / 20D Gripped, EF 70-200 2.8L, [COLOR=black]EF 100-400 IS USM L, EF-S 17-55 2.8 IS USM, EF-S 10-22 USM, Sigma 105mm 2.8 EX Macro, Kenko 2XTC DG Kenko 1.4TC DG, Kenko Extension Tubes DG 12-20, Canon Speedlite 580EX, Manfrotto Tripod!
racketman
Gallery: 20 photos
Jun 15, 2007 14:59 |  #2
quite a few in that gallery taken at 2.8, even #1 the best is only 5.6. DOF is shallow in macro so unless looking for a particular effect you should be aiming to use f7-16. ISO800 can be a bit noisy, best to use ISO 200 or less so use of flash is normally recommended.
Toby
Overkill
Jun 16, 2007 00:23 |  #3
racketman wrote in post #3383588 (external link)
How can i use the flash when i am so close to the subject?:D
rrdjserv@earthlink.net
Jun 16, 2007 08:40 |  #4
Very nice subjects. Racketman gives good advice.
If you are using a built-in flash, try to reflect it. Or get a reflector. Or get a removable flash. Or get a ring flash. Or wait until you have good sun. Or get a fast macro lens. Are you using a tripod?
These are good shots. --Rick
Sigma 500mm f/4.5, Canon EOS 7D, Canon T1i, Canon 300L f/4 IS, Canon 100mm macro, Tamron 17-50, Kenko extension tubes, Canon 580 Speedlite
--Rick
skylab
Jun 16, 2007 08:46 |  #5
rrdjserv@earthlink.net wrote in post #3386901 (external link)
If you are using a built-in flash, try to reflect it. Or get a reflector. Or get a removable flash. Or get a ring flash. Or wait until you have good sun. Are you using a tripod?
If you have a ping pong ball cut it in half and put it over your on board flash it will diffuse the light, you might have to use flash compensation.
Brian :-D
Lester ­ Wareham
Moderator
Gallery: 3035 photos
Best ofs: 5
Jun 16, 2007 10:15 |  #6
Good start, not sure what you are using to get your macro shots, is it your 50/1.8 and tubes?
I would stop down a bit more.
For flash use your 550EX on a bracket (see sticky at top of macro section) or get a macro flash, either the ring flash or better still twin flash. But before you start investing in macro flash you might want to get a macro lens, 100mm is a good length.
Macrophotography by LordV
Overkill
Jun 16, 2007 12:21 |  #7
Lester Wareham wrote in post #3387252 (external link)
hmmm a few shots are made with my old S7000 Fuji.
I have a 550EX flash! Would my pictures be better if i used a flash???;)
Lester ­ Wareham
Moderator
Best ofs: 5
Jun 17, 2007 03:04 |  #8
It makes it a lot easier to start off with.
More light to stop down by, minimal shake and subject movement problems because of the short duration, less dependent on ambient light.
Natural light is lovely, but it is harder. Much above life size I almost always use flash.
dpastern
Jun 17, 2007 05:46 |  #9
Some good shots there Richard - agree with RM that stopping down will help with DOF, unless you're deliberately after that type of effect. You may want to try the 580 flash, and buy a flash bracket and Canon offshoe adaptor #2. Oh, and get a diffuser as well, either something like the Lumiquest Softbox II (which seems to be quite good from what I've seen), or make your own - you might even want to try making LordV's Coca Cola diffuser (just search for posts mentioning coca cola for the user lordv).
Dave
Overkill
Jun 17, 2007 12:34 |  #10
dpastern wrote in post #3390849 (external link)
Dave
I own a 550EX! Can i do the same with the 550 as with the 580?:D
dpastern
Jun 17, 2007 23:48 |  #11
Yes.
Dave
Overkill
Jun 19, 2007 12:43 |  #12
dpastern wrote in post #3395151 (external link)
Yes.
Dave
I will give it my best shot!!!
Any advice on (if i want to invest) what kind Macro lens wil be a good choice!
dpastern
Jun 19, 2007 18:34 |  #13
100mm f2.8 Macro.
Dave
AirBrontosaurus
Jun 19, 2007 18:42 |  #14
I second the 100mm macro. It's an absolutely spectacular lens for insects, and it's priced pretty reasonably too.
Dave: you know you'd save yourself some time if you just put "Dave" in your signature ;)
Chris | My Flickr (external link) | AirBrontosaurus.com (external link) | Peleng 8mm Fisheye writeup (external link)
Body
: Canon 5D
Lenses: Canon 24-105mm f/4 L | Canon MP-E 65mm Macro | Canon 85mm f/1.8 |
Overkill
Jun 20, 2007 01:10 |  #15
AirBrontosaurus wrote in post #3406545 (external link)
I will try to buy it on ebay... what is a good price for a second hand!:)
2,425 views & 0 likes for this thread, 9 members have posted to it.
Ultimat Macro?
2817 guests, 164 members online
