nor will it recognize the card when I put in my card reader. Any ideas why this might be happening? If I put a CF card from my 30D my mac recognizes it.
col4bin Goldmember 2,264 posts Joined Feb 2006 Location: San Francisco, CA More info | Jun 16, 2007 00:21 | #1 nor will it recognize the card when I put in my card reader. Any ideas why this might be happening? If I put a CF card from my 30D my mac recognizes it. Frank
Jun 16, 2007 00:33 | #2 I think it's the memory card. The camera will take pictures however the card cannot be read. It is a brand new card, formatted in the camera. I tried on older card I had and it worked fine. Frank
davidfig we over look the simplest things 3,275 posts Likes: 85 Joined May 2005 Location: Fremont, California USA More info | Jun 16, 2007 02:19 | #3 Format the card in computer then try it in the camera. 5D | 17-40L | Tammy 28-75 2.8 | 28-135 | 50/1.8 | 85/1.8 | Sony A6000 2-Lens Kit | SEL35 1.8 | EF 50 1.8 on NEX as my 75mm 1.8
Jun 16, 2007 06:12 | #4 davidfig wrote in post #3386248 Format the card in computer then try it in the camera. my compter will not recognize the card in my reader Frank
Jun 16, 2007 09:34 | #5 try unplugging the card reader and replugging it in.
Jun 16, 2007 14:18 | #6 MDJAK wrote in post #3387087 try unplugging the card reader and replugging it in. I'm having no problems with the 1d III, except Lightroom will not recognize RAW files from it. I tried all that. It must be the card. I tried another card and it works fine. The new card is higer speed card. Could it be that my reader will not work with it? Frank
Jun 16, 2007 15:28 | #7 UPDATE: I installed the EOS utility software and I am able to get the files off the card. I am using a Hoodman RAW 280x card. My fastest cards before this were sandisk ultra II. COuld it be that my card reader is not capable of reading fast cards? Frank
Sweedishcarrot01 inactive 1,392 posts Likes: 2 Joined Jun 2006 More info | Jun 16, 2007 15:32 | #8 I will post here so I find out the answer also. I will by a faster card (over 200x) soon, and want to know if it will work with my card reader.
Jun 16, 2007 15:46 | #9 NZFritz wrote in post #3388245 I will post here so I find out the answer also. I will by a faster card (over 200x) soon, and want to know if it will work with my card reader. Question: did you try plugging the camera into your mac directly with the usb cable? Oh, and did you try using the disk utitlity to format the card? I tried plugging my camera directly into my mac. For some reason, EOS Utility does not automatically launch like it should. I have to manually launch it. Once I do that I can grab the pictures off the card. This is not my preferred method. I prefer a card reader. Frank
Sweedishcarrot01 inactive 1,392 posts Likes: 2 Joined Jun 2006 More info | Jun 16, 2007 16:15 | #10 Although your computer does not appear to recognise it, when using the disk utility (located in your applications folder - or search using spotlight) you may find that it will come up anyway within that program - you can format/repair it from there...
Jun 16, 2007 17:25 | #11 NZFritz wrote in post #3388399 Although your computer does not appear to recognise it, when using the disk utility (located in your applications folder - or search using spotlight) you may find that it will come up anyway within that program - you can format/repair it from there... ![]() It still does not show up Frank
Sweedishcarrot01 inactive 1,392 posts Likes: 2 Joined Jun 2006 More info | Jun 16, 2007 19:15 | #12 hmmmm, happens...
wlescall Senior Member 512 posts Joined Mar 2006 Location: Northern Panhandle, WV More info | Jun 16, 2007 21:27 | #13 Does the card show up on another computer? Bill
Jun 16, 2007 23:26 | #14 wlescall wrote in post #3389515 Does the card show up on another computer? Do the pictures taken that are on the card show up on another computer? How old is the card reader and how big is the card? The Aperture issue is probably due to Apple not yet updating it (or OSX) to read the new Canon raw files. This usually happens after new cameras are released and new features of the cameras. This may also be the root cause of the card problem and why the files can be read by EOS Utility. For the Lighroom issue, Adobe just updated Adobe Camera Raw. This might fix that. There are also new features to ACR 4.1 . No, the card does not show up on another computer. I tried on a pc as well. I can take pictures with my camera and get them on my mac using EOS utility. The card is a 280x 2gb card. the card reader is 2 years old. Frank
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Jun 17, 2007 03:42 | #15 I'd probably avoid odd branded cards, stay with Sandisk, Kingston, Lexar, etc. If you must buy weird branded cards consider buying their reader, though they should all be compatible i've found that's not true in practice. Lexar seem especially fussy, and some lexar cards won't read in my sandisk reader. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
| Latest registered member was a spammer, and banned as such! 2707 guests, 147 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
